20 Most Recent
Digihome LCD TV Questions & Answers
Netflix stopped working on Digihome t.v.
you guys up there, should be answering down here :>D
- Brett Duxbury Mar 18, 2022Hi Valerie Selden, how is tv connected to internet ?
Can you please add details in the comment box?
how does tv get its ip address ?
Valerie Selden Mar 18, 2022
Hi Brett, there is a data cable which goes from the t.v. direct to the wifi broadband hub, and Netflix won't work when that is connected, or when it isn't. I'm not sure how the t.v. gets the IP address - apologies - not very technical! We have checked all the cables. Netflix told us that the problem was with the t.v. but the Digihome support line number on the internet doesn't connect to anything.
Larry Ng Mar 18, 2022
Valerie
no title movie told
not told is movie 4k UHD. huge.
at home, or work , guess home
is this TV connected via wifi or wired Ethenret to the router.
other TV is where, same home or a friends house.????
the TV if using wifi , must be in range of the wifi of your router. 25' or less best.
no TV model told at all (rear label)
not told does failing TV fail on other 10000 streaming sources>? like Tubi or amazon, or hulu, or others.(endless)
NO TV TOLD AT :: sad face...
old TVs have OLD netflix player and was banned long ago.
the cure for that is buy a ROKU device.
does PC work there? using same connection?
wifi /ethernet
does this pass, 10 up is best. mine is 600https://fast.com/
here is what netflix tells you about
speed
https://help.netflix.com/en/node/306
back of TV has model sticker
age matters here. this model?
wild guess, 50"
50278FHDDLEDCNTD or
LCF501080SNBSM (circa 2016, 6 years old)
yes
page 19 in the manual states
You can navigate between menu tabs by pressing left/
right buttons. The help bar on the bottom of the dialog
shows features that you may use. Press BLUE button
to check your internet connection speed.
You can check the signal strength by using the network
settings menu for the wireless device mode
my guess is connection speeds low .
no connection told wired or wireless?
do other PCs work here? same connection path be it wired or wireless ? same?
Brett Duxbury Mar 19, 2022
was wondering if ip lease expired on the TV from the Router dchp server.
My Digihome tv 32913LCDDVD is stuck in standby
Count the number of flashes occur at one time switch ON. These flashes are called blinking codes; and are fault indications. Form the number of these blinks, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details about these blinking codes, check the site linked here.
Pull up previous posts by its left sidebar, or
type in the
brand name and model number to of your set, to its search
box, and press '
Enter' or view it in
Mosaic / Timeslide option.
My Digihome Smart TV has currently gone into a blank grey screen, it will not work with the remote and the sound isn't working and it's saying its on but it isn't responding, what should I do?
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Black and white
Yes your player has gone into a wrong region make sure that if your tv is pal it must be pal NTSC will also make it go black and white check tv input and DVD player settings
Tv will not switch on
You probly got the button wet you will havev to try use a hair dryer in the eges and blow it dry or you have poped a fuse pop the back of look for a glass tube fuse it's only 1cm big it could also be white just check it will cost about 1 dollar for the fuse
