20 Most Recent Tevion AP-DVR18 DVD Recorder Questions & Answers
Flashing green ligh
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
8/26/2017 1:36:32 PM • Tevion AP-DVR18... • Answered on Aug 26, 2017
Tevion dvd recorder te1201cant get past blank screen after changing set up
Throw it away in some ponds nearby.
8/26/2017 1:35:02 PM • Tevion AP-DVR18... • Answered on Aug 26, 2017
No power
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
8/26/2017 1:34:09 PM • Tevion AP-DVR18... • Answered on Aug 26, 2017
Tevion drw 1605 hdd firmware update
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
8/26/2017 1:29:42 PM • Tevion AP-DVR18... • Answered on Aug 26, 2017
0answers
I am unable to auto tune my Tevion DVD Recorder
If the recorder is old the analogue/digital change is screwing it up. It isn't the TV that is the problem, it is the received signals, but the problem is the same.
12/28/2013 8:11:13 PM • Tevion AP-DVR18... • Answered on Dec 28, 2013
I have a Tevion TLCDD1937 THE DVD WILL NOT EJECT AFTER PRESSING OPEN
There could be a few reasons why your Tevion TLCDD1937 DVD player is not ejecting the disc when you press the open button. Some possible causes include a malfunctioning eject button, a problem with the internal mechanism that opens the disc tray, or a software issue. Try unplugging the device from power and wait few minutes then plug it back in, this may resolve the problem. If the disc is still stuck, try gently pushing it back into the tray and then pressing the eject button again. If the disc still does not eject, you may need to consult the manufacturer for further troubleshooting or consider taking the device to a professional for repair.
1/12/2023 1:03:22 PM • Tevion Televison... • Answered on Jan 12, 2023
My Tevion W42-74G-GB-FTCUP Television won't turn on?
Question edited for clarity. Changed from one long, rambling sentence into lots of sentences. The problem with power cuts is two fold. What caused the outage? If it was a lightning strike, some of the stray voltage 125,000 volts can get as far as the set destroying everything inside it. When the power comes back on, there is often a surge and dirty AC signals until it stabilizes. You may be able to claim for the damage from the electricity utility company. It needs professional diagnosis or just buy new. You can check inside to see if there is a small glass fuse on the power supply. https://www.fixya.com/support/r29790007-repairing_own_television ...
1/3/2023 8:57:16 PM • Tevion Televison... • Answered on Jan 03, 2023
User manual for a TEVION UR 1703
Yes, it is a very little known make. Only scam sites offering it. Universal Remotes were popular in the 80's and 90s, but no one uses Universal remotes these days, you buy a 'facsimile remote', which is an exact copy of your original remote. Google (make of television) model remote replacement This for a Tevion UR4200 on a trusted site https://www.manualslib.com/manual/1253444/Tevion-Ur4200.html https://www.google.com/search?q=TEVION+UR+1703 ..
8/29/2021 3:33:01 PM • Tevion Televison... • Answered on Aug 29, 2021
Have sound, but why no picture?
lts probably the connection issue, it can be a faulty cable cable, improper installation or a bad connection. their may be a video output setting on the device that you must set properly before it will output to the TV. if your display occurred while your your TV is connected to other device like a DVD player, try to change the TV port. if the problem persist you might have an issues with your HDMI cable.
1/10/2021 8:36:57 PM • Tevion Televison... • Answered on Jan 10, 2021
Hi, I need the 3 digit passcode for Tevion TV,DVD. Model number AC19LHC2
Hi, try these combinations- 388, 446, 447, 448, 449, 450, 451 and 452
9/21/2020 8:15:52 AM • Tevion Televison... • Answered on Sep 21, 2020
Looking for a remote control for a Tevion dvr/vcr combo Model 3215, manufactured in 2003.
Chances of buying an original replacement are virtually nil. A universal will only provide basic functions but you should be able to order a compatible remote control online that will enable access to onscreen menus.
5/28/2020 11:01:12 PM • Tevion Televison... • Answered on May 28, 2020
USER MANUAL FOR TEVION CLOCK P1097
I was unable to find the manual but you can refer to the link below for some guidance: http://www.fixya.com/support/t15493826-set_time_tevion_alarm_clock Hope this helps.
10/28/2019 1:46:08 PM • Tevion Televison... • Answered on Oct 28, 2019
I have Tevion DVD VHS o TEV605 but no manual. Can someone tell me how to copy VHS to DVD please.
Converting VHS to DVD with a DVD recorder is quite easy. You need a DVD recorder, a VHS player and your VHS cassette, an RCA or S-Video cable. For more and you can click into the tutorial.
7/11/2019 3:01:49 AM • Tevion Televison... • Answered on Jul 11, 2019
2answers
I bought a Tevion TEV605 vcr/dvd recorder second hand, without remote. Solely for the purpose of copying our old VHS to Dvd. The recording process works fine and will playback in the machine but the dvds cannot be read on other devices. The discs aren't finalising, does anyone know how I can finalise the disc? Or do I need the remote to do this? Thanks in advance
You can finalise any disk on a computer as this will close out the session and make it playable. If you software wont directly let you directly finalise it, then copy the files to the computer and then burn them as a video disk. Nero will do this.
5/24/2019 3:12:19 AM • Tevion Televison... • Answered on May 24, 2019
Where do i find a remote control for my Tevion 19" TV/DVD model 1961?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. https://homenol.blogspot.com/ https://electrohelponline.blogspot.com/ https://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts. /
5/18/2018 5:27:12 PM • Tevion Televison... • Answered on May 18, 2018
Tmy tevion tv needs retuning every few days, what is the proplem?
First check the aerial's cable coaxial(coax) plug/s is/are ok. Poor signal strength can cause this problem - all bad coax connections drop signal strength.
12/29/2017 1:03:09 PM • Tevion Televison... • Answered on Dec 29, 2017
Tevion AX32P1 TV remote where can I get one?
Try ebay. eBayeBay
9/10/2017 2:22:03 AM • Tevion Televison... • Answered on Sep 10, 2017
Codes for urc22b 8 in 1 tv remote for tevion tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
8/26/2017 1:37:58 PM • Tevion Televison... • Answered on Aug 26, 2017
Tevion AP-DVR18 DVD Recorder Logo
10 questions posted
Top Tevion Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Larry
Are you a Tevion Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Tevion Televison & Video
Most Popular Question
flashing green ligh
  • Televison & Video
