20 Most Recent Sanyo DP26640 LCD TV Questions & Answers
Sanyo 26 in goes off and on by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/6/2017 11:31:01 AM • Sanyo DP26640... • Answered on Jul 06, 2017
0answers
Sanyo DP26640 LCD TV won't power up. Is there a fuse somewhere inside?
Every TV will have an AC fuse inside. This fuse can be located at its main power regulator [SMPS] board. This is a protection fuse; and if it is found burned [open], there should be sufficient reason for it. some kind of short circuit, or over voltage etc: Replacing this fuse without make sure, about the cause to burn the fuse; the newly inserted fuse too will fail, and more damage to set can occur. So, it is better to contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
7/23/2016 2:18:31 AM • Sanyo DP26640... • Answered on Jul 23, 2016
I can't get the input to work. Neither the remote or the button on the side will get me to that menu where I can select HDMI. Worked fine yesterday.
The tv needs a hdmi signal to enable selection on screen. My guess is that there is something wrong with the hdmi cable or the output device (video player, cable box or such}
3/27/2016 6:30:32 PM • Sanyo DP26640... • Answered on Mar 27, 2016
The input selection on my Sanyo DP26640 has stopped working. Neither the remote button or the one on the side of the TV functions. Worked fine last night.
Check and replace the main system control memory IC. Before doing anything; just try a hard reset first. If it do not help you, do the replacement said above. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
12/17/2015 2:18:04 PM • Sanyo DP26640... • Answered on Dec 17, 2015
2answers
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
12/17/2015 9:10:48 AM • Sanyo DP26640... • Answered on Dec 17, 2015
Is there any way to get audio out of the headphone jack to drive external speakers?
ONLY ON SMALL SPEAKERS, you can add headphone jack plug to any speakers an plug them in
9/17/2015 8:48:35 PM • Sanyo DP26640... • Answered on Sep 17, 2015
Set turns on but after a few minutes get a scrambled screen then goes off and has problems coming back on
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
6/14/2015 2:39:00 AM • Sanyo DP26640... • Answered on Jun 14, 2015
How do I fix a no power up no green light tv?
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
6/6/2015 4:31:53 AM • Sanyo DP26640... • Answered on Jun 06, 2015
How do I change my HDMI Input Signal Resolution?
It automaticly adapts to the provided resolution. You have to change the source like blueray player or computer
1/2/2015 10:12:51 PM • Sanyo DP26640... • Answered on Jan 02, 2015
When is turned on it comes up please select proper location and when select up or down channel It will notprogram
To select proper location (home mode)you must use the CURSOR keys to highlight the desired option and press the ENTER key. Then use the CURSOR keys to highlight the Signal Search option and press the ENTER key.
12/13/2014 10:12:32 PM • Sanyo DP26640... • Answered on Dec 13, 2014
How do I change my audio setting
It depends on what you want to change about your audio setting. My cable box remote has two audio settings: one for changing the SAP language sound from English, to Spanish or French; and a setting that changes two separate audio functions: one changes the broadcast sound from Dolby Digital (TM) sound to regular stereo sound, and the other will allow using either a fixed setting (cable box sound level is at a fixed level allowing one to use the sound control on the TV, or other audio receiver), or a variable setting (allowing the use of the cable box to adjust the audio level). My Sony TV control also allows me to adjust the tv's audio treble, bass, balance, and special effect sounds, and if needed, to turn the tv speakers off. Hope this is helpful..................Gary
6/20/2014 4:45:14 PM • Sanyo DP26640... • Answered on Jun 20, 2014
How do you zoom with no remote
To zoom in and out, you should have its remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Universal remote controls are available at most of the electronic spare part selling shops.
6/8/2014 4:54:16 AM • Sanyo DP26640... • Answered on Jun 08, 2014
0answers
No picture
Be the first to answer 5/22/2014 4:03:03 AM • Sanyo DP26640... • Posted on May 22, 2014Be the first to answer
Remote lm 1075 codes 1165
0381,0383,0389,0366. Try these codes. For more information, check these links. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
11/16/2013 12:07:34 PM • Sanyo DP26640... • Answered on Nov 16, 2013
Sanyo DP26640 LCD TV Logo
46 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
fix no power up no green light tv
  • Televison & Video
