20 Most Recent Luxor 19822 COB Questions & Answers
How can i find my tv code on fuego smart tv
Luxor 19822 COB | Answered on Apr 30, 2019
you cannot eject using remote. Press the stop button on the side 3 times to eject
Luxor 19822 COB | Answered on Jun 23, 2018
Try a hard reset first. If it do not help you, check and replace its main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Luxor 19822 COB | Answered on Aug 15, 2016
You may have checked the fuse at the plug...is the socket OK itself? Plug something else into the socket..to make sure it's working...If your not technically minded...don't open up the back of the TV set, but there may be a fuse there also on the main board.. RISK OF SHOCK.
Luxor 19822 COB | Answered on Jun 29, 2016
I do not want to state the obvious, but have you looked all over it for any control panel?
Can I suggest ....if you have not already done so.....Switch off from the power button. Switch off from wall socket. Leave for a few minutes. Plug in..switch on....Make sure if you have a remote the batteries are OK..renew if you need to.
In front of the TV , below the screen
Luxor 19822 COB | Answered on Nov 09, 2015
check cable connection
Luxor 19822 COB | Answered on May 12, 2015
Sounds like tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Luxor 19822 COB | Answered on Jan 25, 2015
Main system control memory IC fault. Contact any service technician to replace it.
Luxor 19822 COB | Answered on Jul 27, 2014
You might have pressed the AV selector botton on the side panel of the TV. It works as a toggle type switch. Press on once will select the TV input, and for an other press will come back to AV and so on.
Locate that switch you have pressed earlier, and press it once more, to select the input to TV.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Luxor 19822 COB | Answered on Jul 12, 2014
Luxor 19822 COB Logo
65 questions posted
Top Luxor Televison & Video Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Luxor Televison & Video
Most Popular Question
need manual luxor tv remote 19000 model
  • Televison & Video
