20 Most Recent
Apex Digital DT502 Questions & Answers
Comcast remote codes for apex digital dt502
Brand: Apex Digital
Most likely code: 10765
Others to try:
10748, 10879, 10767, 10890, 11991, 10889
To program your remote:
- Turn on your TV
- Using the code list, find the first five digit code that is listed next to the name brand of the TV that is to be programmed
- On the Comcast remote, press and release the TV key
- On the Comcast remote, press and hold the SETUP key until the TV mode key blinks twice then release the SETUP key
- On the Comcast remote, enter the first listed five digit code
Note: If this number is entered correctly and is an accepted TV code, the TV mode key will blink twice. If the code is entered incorrectly or is not an accepted TV code, the TV mode key displays one long blink and exits programming mode
- Aim the remote control at the TV and press the POWER key once
- The TV should turn OFF - if it did not turn off, repeat steps 1-6 with the next TV code listed, until a working code is found
Tv channel scan
If you are using cable TV the channels could all be scrambled requiring a cable decoder box.
I have a apex digital
WHY would you want to do that? Are the TV speakers better than your Apex?
If your TV audio and video are all passing through the HT first (from elsewhere, like a cable box) you might want to run basic analog audio directly from that source to the TV so you can watch news and such low-fi content without the HT.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
