20 Most Recent Jensen SMPV Questions & Answers
To set stations, press set button on far right then search station then press number station is to be set.
Jensen Audio... | Answered on Jan 15, 2020
Hi Tom-
I found this link regarding Jensen CS 315 speaker specs. Click on "See More" for further information.
https://picclick.com/JENSEN-CS-315-3-WAY-MONITOR-STEREO-SPEAKERS-8-184010428853.html
Hope this helps.
Jensen Audio... | Answered on Jan 09, 2020
Bill,
Sorry that I have to be so general in answering this question. If there is a burnt smell associated with the occurrence of the problem, then that would point to a fault most likely in the audio output circuit. If the unit blows a fuse, then I tend to think that it is in the power supply of the internal amplifier. Either way, service is needed for the unit. It is best to disconnect the unit from your sound system and try to find someone qualified for this repair.
Jensen Audio... | Answered on Mar 29, 2019
Does your Jensen have the AUX inputs on the back or front? You would need to find a Satelite radio with the Outputs that will plug into the AUX Inputs. Some radios have a special input connections for Satelite radios, so check the Manual.
Jensen Audio... | Answered on Jan 25, 2019
They make a special spray for that purpose.
Jensen Audio... | Answered on Apr 06, 2018
Page seven of a similar model manual
http://www.spectraintl.com/images/stories/pdf/jn/UM/JCR-310_EIB.pdf
1. With the unit in Standby mode, press and hold the TIME SET button for about 1 second
2. Press the (two right triangle / two left triangle buttons) to adjust the hour.
3. When the correct hour is selected, press the TIME SET button to confirm and the "minute digits" will begin to flash on the display.
4. Press the (twwo right triangle/two left triangle buttons) to adjust the minutes.
5. When the correct minute is selected, press the TIME SET button again to complete the setting.
Jensen Audio... | Answered on Mar 02, 2018
Jensen SMPV Logo
9 questions posted
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Audio Players & Recorders
Most Popular Question
jensen jmc 1200bk cd player will not
  • Audio Players & Recorders
