20 Most Recent Whirlpool Mastermind Questions & Answers
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Refrigerator.
Whirlpool... | Answered on Jun 20, 2017
the total set swict of the device and and start the ofter 2 hours
Whirlpool... | Answered on Jan 09, 2017
I think you meant $1950.00 The unit in my opinion is worth maybe four hundred bucks or so. That would also depend on the appearance and also the quiet smooth operation of the refridgeration.
Whirlpool... | Answered on Apr 30, 2014
try cleaning the condenser section, under the unit there is a fan that may be dirty or hitting something, clean it out.
Whirlpool... | Answered on Apr 25, 2014
Do they drain away down the back? It is probably just an automatic defrost cycle. check the stock temperature is ok
Whirlpool... | Answered on Apr 22, 2014
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope this helps.
Good luck.
Whirlpool... | Answered on Nov 28, 2012
call the owner or manager and ask them to get it fixed
Whirlpool... | Answered on Aug 05, 2020
Contact Whirlpool or a Whirlpool retailer to inquire.
Whirlpool Mastermind Logo
20 questions posted
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
power controll card 2290 240008
  • Refrigerators
