20 Most Recent Russell Hobbs RH1042 Frontload Washing Mashine Questions & Answers
Water comes in the back, then goes via to solenoid valves to the back of the powder tray, it then is distributed through holes above each compartment, take out the powder tray (push down the blue bit at the back of the softener compartment) and check for cracks or even blockages, (water goes from tray down the back and through a short rubber hose straight into the drum.
Russell Hobbs... | Answered on Oct 21, 2016
More than likely belt gone, otherwise the motor has gone.
Could be bearings, look to be around £23 online, no idea how easy to replace though.
I find quite often I have to turn it anticlockwise for it to allow me to start it again, or wait for a short while (my plug is behind the machine)
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Russell Hobbs... | Answered on Jul 12, 2016
I think this indicates a fault i.e. unbalanced load, I had the same when I tried to washable pillow. Went through all cycles but spin.
Russell Hobbs... | Answered on Feb 12, 2015
The second to last on the dial (picture of a spiral), if it's the same as mine.
Sounds like something toasted on the control panel
Better call certified appliance repairman
Russell Hobbs... | Answered on Oct 08, 2014
You have a problem with your knob or switch it may be burned out I would get on Craigslist and find a free one meaning a matching one or a whole working unit there on there all the time in free stuff sometimes matching sets
Russell Hobbs... | Answered on Aug 07, 2014
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
What's the model Number?
Russell Hobbs... | Answered on Jun 08, 2014
Your machine is trying to tell you something-do you have the owners manual-if you don't I'd bet you could find it online-what I would look for is an explanation of the flashings-it will probably tell you to count the number of flashes to tell you what is going on-cheers denny
Russell Hobbs... | Answered on Oct 24, 2013
Russell Hobbs RH1042 Frontload Washing Mashine Logo
48 questions posted
Top Russell Hobbs Washing Machines Experts
Marvin
Marvin
Are you a Russell Hobbs Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Russell Hobbs Washing Machines
Most Popular Question
washing machine russell hobbs rh1042
  • Washing Machines
