20 Most Recent Pfaff Creative 4.0 Sewing Machnie Questions & Answers
I have a pfaff creative 4 and it won't zig zag, just keeps saying that the machine is set for straight stitch. How do I change this? changing the stitch width setting doesn't make any difference
Look under the tools menu. There should be a setting for straight stitch needle plate or something like that. good luck! Wayne
10/6/2016 1:00:11 AM • Pfaff Creative... • Answered on Oct 06, 2016
Bobbin not in position, won't let me get cotton from bottom - snags on part
Look for bent bits! Also try a new bobbin/ if it's the type that locks into position, there maybe an issue with the lock on that bobbin. Once you load the bobbin, slowly turn the flywheel intil you feel the thread snag and see where the boo in is facing-will give you a better chance of solving issue. Also, if there is a thread tensioner, turn it way down....
4/5/2015 2:55:42 AM • Pfaff Creative... • Answered on Apr 05, 2015
PFAFF QE4 It won't let me adjust thread tension, help
The tension setting adjustment is found in the tools menu
3/5/2015 4:55:01 AM • Pfaff Creative... • Answered on Mar 05, 2015
3answers
Message remove thread jam under the stitch plate keeps appearing! It's clean!
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again. Keeping my fingers crossed.
1/22/2015 5:18:06 PM • Pfaff Creative... • Answered on Jan 22, 2015
Needle won't go down fully
The presser foot will not go all the way down to the plate with straight sewing and embroidery sewing as well leaving me with a jumbled mess
1/3/2015 12:52:38 AM • Pfaff Creative... • Answered on Jan 03, 2015
Removing top cover on pfaff creative 4.0 embroidery machine
May be, you have not the right tools to open your pfaff chassis. In your case I prefer to get support from pfaff: http://www.pfaff.com/de/692.htmlIt's a risk to open the chassis, you can't see, where it is fixed. If you try to open, the risk is high your pfaff will take damage.
12/24/2013 7:44:24 PM • Pfaff Creative... • Answered on Dec 24, 2013
0answers
Hasp h0007
Be the first to answer 10/9/2013 4:16:45 AM • Pfaff Creative... • Posted on Oct 09, 2013Be the first to answer
Thread keeps breaking
The top thread breaks1. the needle thread is not threaded properly2. The needle thread tension is to tight3. The needle is bent or blunt4. The needle is incorrectly inserted5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew6. the threads were not drawn to the rear after sewing7. The thread is either to heavy or to fine for the needle8. Try a different spool or cone of threadBobbin thread breaks 1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly 2. Lint has collected in the bobbin holder 3. The bobbin is damaged & doesn't turn smoothly 4. Lower thread tension is two tight
9/3/2013 3:38:05 PM • Pfaff Creative... • Answered on Sep 03, 2013
My thread keeps breaking every time I start sewing
9/3/2013 3:36:39 PM • Pfaff Creative... • Answered on Sep 03, 2013
Thread caught behind the bobbin case holder
Take off the presser foottake off the needle platetake off the bobbin platetake out the needle, clip bobbin free, Examine the bobbin carrier on how it fits into place. (important) Lift out the bobbin carrier. Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost. Have fun.
11/6/2012 6:28:40 PM • Pfaff Creative... • Answered on Nov 06, 2012
Won't free motion quilt
Did you drop the feed dogs?
9/13/2012 1:51:38 AM • Pfaff Creative... • Answered on Sep 13, 2012
Pfaff Creative 4.0 Sewing Machnie Logo
48 questions posted
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • PfaFF Sewing Machines
Most Popular Question
message remove thread jam under stitch
  • Sewing Machines
