20 Most Recent
Advent Modena M101 Questions & Answers
Microsoft isatap adapter
Hi Rufus.
Your problem is in your registry. To fix it you will have to download some or the other Optimisation and Regiter Cleaner program. I have so far not been able to find a reliable free program. I personally use the AVG PC Tune-Up program which is fairly inexpensive and very effective.Just search for the program and download it free. It will give you a short trial period before you have to pay. This program will help you to solve a multitude of problems on your PC.
How do i get webcam up its built in on advent t3100
You can connect to internet and follow the procedure
go to --- my computer > right click on it > go to properties > device manager > click on the computer name shown in device manager screen >click scan for hardware changes > then the driver will install automatically .
Wallpaper on laptop wont work
right click on any paicture in your computer and select set as walpaper. If it doesnot work, reinstall Operating syste,.
How to replace screen
thats like asking how long a bit of string is, look on youtube, there is loads of video there.
No power. I press power button and only see red
measure the output from adaptor example if the label printer says:17,8vdc, you will measure the exaclty 17,8 if do not , the adaptor is faulty. However the comuter must be run with the battery, of course must be full in charge. If does is o.k If it NOT , the power supply inside is faulty.repairGod bless you
No power in my laptop. I press power button and
please measure the output voltage from the adapter , see the label printed in your adaptor if the voltage read with the exactly voltage: exampe label printed: 17.8, and you measure 17.8 the adaptor is o.kIf do not the adaptor is faulty. repair or replaceHowever you must try with the battery to Start, of course the battery must be charged in full, if the battery is o.k the laptop will be on. If not the power supply inside is faulty. REPAIR.God bless you
How do I disable touchpad
usually you have to press both Fn ( the blue button next to the right control button ) with F7 button . if it doesn't work please specify what is the brand of your pc and which model .
M101 keyboard replace
Keyboards are usually screwed in on the top of the laptop as well. Try to pop off the plastic cover above the keyboard, there should be little slots to allow you to take it off. Then there should be some screws under there for the keyboard.
