20 Most Recent
Maxell 500gb Genpro External 25inch With Continuously Automatically Backup USB 20 Hard Drive Questions & Answers
Maxell 500gb formatting problem
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps you
Maxell myGEN MY-500 Plugged in, blue light on, not
No hard drive in the last 30 years needed drivers installed except for a short time when SATA hard drives first hit the market with Windows2000 and XP. I believe that is an external drive usually used for backups. You did not post your operating system, and if this is a new drive or one you have had for some time. So I will use Windows7 and assume this is a new purchase:>Try a different cable and a different USB port in case the cable or port went bad. It happens.>Plug the drive into a different computer. Is it recognized?>Go into Device Manager; is it listed?>Enter Control Panel/System & Security/Administrative Tools/Create & Format Hard Disk Partitions. Is your drive shown there? If it is, Right click on it, then click Mark Partition as Active. Does your computer see it now?If the answer is no to all the above, the drive probably failed.
Maxell max data 1tb hard drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb deviceif you need more help with this post a reply
hope this helps you
My 32 gb flashdrive says that it needs to be formated but will not let me because it is write protected, so can someone tell me how i can format it so i can use it again
click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select openRight click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control.
another way
hope this helps
I can't open the CD
make sure that all leads that attach to your cd: drive are secure and are not faulty
Cd rom won't recognize disk
see if the player tries to read the disc. Load a disc and listen.
Does
the player make squealing noises or is it totally quiet? Squealing
noises may indicate that the player is trying to synchronize with the
disc but can't due to an obstruction on the lens or in the laser path
inside the pickup or a defect in the pickup. This can also be caused by
an intermittent signal problem due to a faulty ribbon cable.
Totally
silent means that the photo sensor is not getting any usable input from
the laser at all, meaning that the pickup is "blind" for lack of a
better word.
This can be caused by an obstruction of the beam by
foreign matter on the lens or inside the pickup all the way to a
marginal or failed laser diode and/or photosensor array. This can also
be caused by a bad ribbon cable with one or more severed traces.
You
could try to clean the optics. This is the most common malfunction as
far as i know in all disc players. It would involve taking the cover
off and finding a way to expose the lense, and then cleaning it with a
very gentle brush. some players have a cover for the lense that swings
to the side during playing, this greatly reduces the chance of dust
accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that
guides the carriage of the laser pickup. Dirt, grome, dust and
solidified lubricant can cause stoppage of the carriage and the laser
eye then fails to read the next track. Please refer to the image i have attached.
