20 Most Recent
Symbol P470-SR1211100FB Handheld Questions & Answers
Cab't get computer/application to recognize
This is an older model handheld that utilizes either and RS-232 cable or Symbol Synapse cable to link to a PC. If the model you are using is cordless, then there should be a dock that is used to connect to your PC.
Most computer peripherals using RS-232 connections require a driver install to the PC in order to recognize the input from the device. Upon successful connection of the handheld or dock to the PC with driver installed, the unit should work as long as there is no physical malfunction to the unit.
The driver utility support the p470 models can be found here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11585&sliceId=&dialogID=227820981&stateId=1%200%20227814895
This unit is only supported by Windows 2000 or Windows XP environments.
Regards,
Dan
IT Professional
5/4/2011 3:04:00 PM •
Symbol...
Answered
on May 04, 2011
My Kenwood 1 ton inverter ac outer not starting some times start show compressor symbol and then turn off and not start again doesn't show any error please guide
If your Kenwood 1 ton inverter AC is having trouble starting and sometimes shows the compressor symbol before turning off, there may be a few things you can check to diagnose the issue.
- Power Supply: Check that the AC is receiving proper power supply, and the circuit breaker is not tripped. Sometimes, due to voltage fluctuation, the compressor may not start.
- Dirty Air Filters: Check the air filters and clean them if they are dirty. Dirty air filters can reduce the airflow and cause the AC to malfunction.
- Faulty Thermostat: If the thermostat is faulty, it may not be able to detect the temperature properly and cause the compressor to not start. You can check this by setting the temperature to a lower level and see if the AC starts.
- Low Refrigerant Level: Check the refrigerant level in the AC. Low refrigerant levels can cause the compressor to not start.
If none of these steps solve the issue, it may be best to contact a professional AC technician to diagnose and repair the issue.
How to type degree symbol on mac
There are a few different ways to type the degree
- Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
- Use the character viewer:
- Go to the Edit menu and select Emoji & Symbols.
- In the search field, type "degree".
- Double-click the degree symbol to insert it into your document.
- Use the ASCII code:
- Press and hold the Option key and the Shift key.
- Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
Videocon ac remote not working
Please reach out to videocon on twitter to help take care of this issue: @VideoconIndia . You can tweet their handle with the issue included.
You can also call 1800 1370 444 to reach them. I believe that is a number based in India. Thank you.
IPhone Google Maps not Talking
On iPhone go to Settings. Scroll down to Maps and touch. Scroll down to Driving and Navigation and touch. Scroll down to Navigation and Voice Volume and ensure that Loud Volume is checked. Push the upper volume button on the side of the iPhone to max ring volume. But this is not all. Here is the secret, which it took me a long time to find out from an obscure post on the web. Open google maps and choose your location (location services must be on) as origin and some other place as destination. Touch Start (varies by screen, whether you have chosen the little angle arrow for directions or are on another screen -- no matter). Now here is the key part of it. Immediately after touching Start, push the volume up button on the side of the iPhone and keep pushing. A little volume symbol will appear on the screen with ascending bar, and you'll start to hear the voice. The problem is that the volume button works with google maps ONLY when the google maps voice is speaking (which happens for a very short time immediately after you touch Start, so you have to be quick). At other times the volume button controls ring volume, not map voice volume. Since you can't hear the google voice in the first place, you don't know when to push the volume up button to make it louder, and you can't change the volume unless the voice is speaking. The above procedure worked for me after I tried many other things and also heard from some sites that it was the new operating system that had disabled the maps voice, which is not the case. I am using an iPhone 5C with IOS 10.3.3. This may not work with other phones. Not responsible for errors or omissions. Your results may vary. Good luck to all.
Hi there, does anyone has Fusion driver 2.0 for Symbol MC3090, since Id updated to Fusion 2.57.0.0.025B from Zebra webpage and from there on my wireless network didnt work. Thanks in advance.
a true relic, 16 years old for sure last one sold new 2011,
support ended 2016 (missed the boat) 2004 first one.
https://www.zebra.com/us/en/support-downloads/mobile-computers/handheld/mc3000.html
what PC, name it and the OS, windows xp to w10., what?
you posted to computers so.....
it is a UPC bar code scanner , as seen in STORES check out.
we have no idea what wireless network any one has, until told.
my wild guess is you are not at home.
only the maker support this old UPC scanner
wireless wifi is
WLAN: 802.11a/b/g
WPAN: Bluetooth
only. and only if opted new.
the manual states
Windows Mobile 6.1 or Windows CE 5.0 device:
no story told, found this in a dumpster or garage sale>?
first time ever to attempt to get it to work?
what is you host, A PC? or what? running what os
The do not have drivers for most popular OS, sorry. and not now.
all there is , is here.
https://www.zebra.com/us/en/support-downloads/mobile-computers/handheld/mc3000.html#pageandfilelist_4c86
Symbol barcode scanner wont read hyphen
That's a very specific question. Without knowledge of all your setup, scanner make/model, the reading software and its config there's not really anyone other than a specialist can help you with.
Sorry.
