20 Most Recent Syntax S845GVM (SYS845GVM) Motherboard Questions & Answers
0answers
Baja resolucion en tarjeta s 845gvm
? No speak spanish.
10/25/2011 4:39:47 PM • Syntax S845GVM... • Answered on Oct 25, 2011
Why am i getting Parse error: syntax error, unexpected end of file in C:\xampp\htdocs\conditionalssf.php on line 66
Google: Parse error: syntax error, unexpected end of file in C:\xampp\htdocs\conditionalssf.php Error fix explained.
2/21/2018 4:24:46 PM • Syntax Computers... • Answered on Feb 21, 2018
0answers
K7SV266AD Can I use
The Syntax K7SV266AD motherboard uses a VIA motherboard chipset.
It uses a VIA KT266A for the Northbridge, and a VIA VT8235 for the Southbridge.
About the motherboard chipset;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
High-speed graphics is AGP or PCI-Express
A graphics card inserted into a PCI slot is Not high-speed graphics.
Neither is Integrated Graphics.
(Integrated Graphics is also referred to as OnBoard graphics.
ON the motherBOARD. The graphics chipset is soldered directly to the motherboard, and not to a graphics adapter card. {Graphics card}
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The Southbridge chip handles the slower capabilities of the computer.
It handles the IDE, and SATA capabilities of the computer.
It also handles the USB ports, Ethernet, and Audio, plus anything connected to a PCI slot, and Integrated Graphics, to list a few examples.
Motherboard Diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[For further information you may wish to search on Wikipedia,
A) Northbridge (computing)
B) Southbridge (computing)
C) Bus
D) PCI Local Bus
E) AGP (Accelerated Graphics Port)
F) PCI Express
G) Front Side Bus ]
Looking at the motherboard with the Processor to the top, and Ram Memory to the right, the VIA KT266A northbridge chip is below the Processor.
The aluminum finned Heatsink covers it.
The VIA VT8235 southbridge chip is down towards the lower right corner.
Looking at the specs for the VIA KT266A chip we can see,
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
1) It supports either DDR Sdram ram memory at 200MegaHertz, or 266MHz.
PC-1600 or PC-2100, respectively.
(DDR Sdram is clocked twice. Therefore the 133MHz Front Side Bus {FSB} support will handle 266MHz ram memory)
2) The Maximum ram memory it will support is 4GB. If you have the motherboard manual, you will know what the maximum amount of Ram Memory is, that the motherboard will support.
3) Will support Processors with either a 100MHz, or 133MHz FSB. (Front Side Bus)
AMD processors are 'Double-pumped'.
The VIA VT266A chip will handle AMD processors with up to a 266MHz FSB.
It will handle AMD Athlon, or AthlonXP, or Duron processors, with a maximum FSB of 266MHz.
http://www.via.com.tw/en/products/chipsets/legacy/kt266a/
The best processor will be an AMD AthlonXP with a 266MHz FSB, that fits in a Socket A (Socket 462) processor socket.
Watch the Voltage used. Look up the AMD processor you have installed now, and see what voltage range it uses. The new processor must use voltage in this range also.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
For additional questions please post in a Comment. (Upper right of your page)
Regards,
joecoolvette
7/4/2011 3:19:28 PM • Syntax Computers... • Answered on Jul 04, 2011
I have no idea if
Going from No wifi connection to reinstalling windows is a big difference in time and maybe documents. If your sure you can't boot and want to reinstall xp the best would be to go into your bios. Its F12 or whatever on your machine just so you get to the bios. There you can select a certain amount of memory that you have to be partioned. Simply all would go for your xp installation. With the xp disk in the drive turn on the machine and it should boot to the installation. If it doesn't your boot order is incorrect meaning the machine is trying to boot from the hard drive and you want the machine to boot from your dvd drive. So in the bios you have to make sure the default boot at least temporarily is the dvd drive. When in the bios that is real simple to change.
With the computer instructed to boot from dvd drive and disc in the dvd drive it will jump to the installation of the xp pro. If you have any questions come back with another and you should get a response as this is a fairly common question
4/7/2011 12:35:39 AM • Syntax Computers... • Answered on Apr 07, 2011
2answers
I have a syntax s651m
Usually the default password is "password" or no password
2/6/2011 7:37:44 AM • Syntax Computers... • Answered on Feb 06, 2011
Dear reader, I
try to find it from here
http://list.driverguide.com/list/company2307/OTHER/
or from here
http://www.bioticaindia.com/driver/d686.html
For any other help or to thank me you can also mail me on my email [email protected]
8/6/2010 11:22:42 AM • Syntax Computers... • Answered on Aug 06, 2010
I have a Syntax K7 SV400 motherboard. The board
My guess is that the CD does not have a boot track, so will not start up.
3/25/2010 11:30:36 AM • Syntax Computers... • Answered on Mar 25, 2010
2answers
My Syntax S635MP motherboard can't take more RAM
It is highly probable the the other chip ( also known as Memory / RAM ) is faulty, hence causing the system to stop working.
Take out the working one and put in the other RAM. if the system does not startup, it is the RAM issue.
Nothing to do with BIOS or Windows 2000.
1/20/2010 2:35:36 PM • Syntax Computers... • Answered on Jan 20, 2010
Where is syntax motherboard support
Sorry, your question doesn't make sense in English.
10/18/2009 2:54:35 AM • Syntax Computers... • Answered on Oct 18, 2009
When I go to web
This sounds like a PHP or Server Side Error, and so there is nothing you can do. Try again on another day, and if the problem persists contact the Site Admin.
3/4/2009 8:01:28 PM • Syntax Computers... • Answered on Mar 04, 2009
Adding a video card
if you have a video VGA plug on back of your computer and it is not an added card, then it is built in. You can disable most on-board video via settings in the rom bios.
1/24/2009 3:45:25 AM • Syntax Computers... • Answered on Jan 24, 2009
What can I do to
what browser are you using?i think you need to reinstall the browser
10/19/2008 5:11:32 AM • Syntax Computers... • Answered on Oct 19, 2008
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered Yesterday
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered Yesterday
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered 2 days ago
Computers & Internet Logo
Popular Tags
2 questions posted
Top Syntax Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Syntax Computers & Internet
Most Popular Question
baja resolucion en tarjeta s 845gvm
  • Computers & Internet
