20 Most Recent Samsung DMT400RHW Builtin Dishwasher Questions & Answers
I had the same problem, SAMSUNG did not want to tell me how to fix so I jumped in with research I found that after you remove the power supply, i.e. plug, 1) you need to remove the dishwasher and turn it upside down. 2) There is a white sensor tray; 12x12 approx. on the bottom held in with two screws, remove the screws and use a flat head screwdrider to undo the clips holding the tray in place. 3) Dry the tray and sensor tips with a towel and replace the tray. Bammmm, you have just fixed the LE(leaking error) code error.
Samsung... | Answered on Aug 13, 2015
Did you get a solution for this problem because my dishwasher is doing the same thing.
Samsung... | Answered on Apr 16, 2013
Samsungs have a power "filter board" in the base of the dw.This is different from the main board. This is most likely the culprit and can be checked with a voltmeter. You should have 120 volts coming out of the filter board if it is working. If not, that is your problem.thanks
Samsung... | Answered on Jan 12, 2020
Go to web site for the significance of this error code - once you know it, you have the clue(s) regarding where to look for your issue problem.
Samsung... | Answered on Dec 25, 2019
A Samsung Dishwasher flashing the Heavy Normal and Quick light indicates a Low Water Level Error has been detected by the internal electronic diagnostics.
You can find more info here
https://appliancerepairinfo.com/samsung-dishwasher-heavy-normal-and-quick-light-flashing/
Samsung... | Answered on Dec 22, 2019
A Samsung Dishwasher flashing the Smart Auto light indicates a Water Supply Error (Not Enough Water) has been detected by the internal electronic diagnostics.
https://appliancerepairinfo.com/samsung-dishwasher-smart-auto-light-flashing/
A Samsung Dishwasher flashing the Delicate and Heavy light indicates a Heater Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-dishwasher-delicate-and-heavy-light-flashing/
A Samsung Dishwasher flashing the Heavy and Normal light indicates a Temperature sensor Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-dishwasher-heavy-and-normal-light-flashing/
A Samsung Dishwasher flashing the Normal light indicates a Leakage Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-dishwasher-normal-light-flashing/
The Delicate light flashing on Samsung dishwashers indicates a drain error. Possibly a pump/motor assy.
Samsung Dishwasher Not Draining
Doesn't sound like a clogged ECS because it's not draining at all.
Samsung... | Answered on Nov 28, 2019
Disconnect the power cord from the outlet and wait for about 2 minutes. Plug the power cord in again. The computer board will probably reset itself, anf there should no longer be a problem
Samsung... | Answered on Sep 29, 2019
Samsung DMT400RHW Builtin Dishwasher Logo
Popular Tags
12 questions posted
Top Samsung Dishwashers Experts
gbob59
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Samsung Dishwashers
  • Samsung Dishwashers
Most Popular Question
samsung dishwasher error light heavy
  • Dishwashers
