20 Most Recent ATN Aries 390 Paladin Weapon Sight Questions & Answers
At night. You can sight in the 390 during the day in simi-darkness with a day light lens cover over the front of the scope. (the snap cover has a small hole in the center for look see during the day) 50 foot room with a target, bench rest and a rifle vise. You'll also need laser bore sight Figure you rifle ammunition ballistic and how many yards before it starts to drop. Set the 390 reticle to the red do on the target one or two inch above. Dead center set up will give you about two hundred yards on center... approx. Now you know this is a static test or sight in. During night because of some distortion and noise from the scope. stewbison
ATN Aries 390... | Answered on Aug 13, 2011
Battery OK, IR light up, no green image on the intensifier image tube, correct! What type of voices are you hearing? Give ATN Aries 390 two Zolof and wait two day, just kidding!!! The noise is a crackling, high freqencey hum, popping, etc. Also remove the eye lens, it screw off, then remove the scope to someplace where it semi dark. Turn it on and observe the 18mm white plate and see if it turn green---no green---no look see---no image intensifier tube, it dead that is the mage tube. stewbison.
ATN Aries 390... | Answered on Aug 07, 2011
Hello - nice looking scope and with 100 % rave reviews.
Not much to adjust really - cover off , battery inserted , turn on - adjust brightness. IR illuminator on'off.
I've just read through page 5 on user manual - at least they have a 2 yr warrantee and some phone numbers to get support.
Here is user manual / guide + trouble shooting tips. http://www.nightvisiongear.com/documents/Aries390PaladinNightVisionRifleScope.pdf
A simple test is looking at a distant street light - just incase the 'amplifier' is very sensitive. (that causes BLACK spots) .
If the amp is damaged , they would have a test -- Ray
ATN Aries 390... | Answered on Jan 23, 2011
Tubes can go without warning, but power supplies usually do. Get someone to check if PSU takes a current at switch on and then measure the HV.
ATN Aries 390... | Answered on Dec 09, 2008
Observe the IR illuminator with a digital camera and see if it if fluctuating in output brightness. If that is OK, the problem may be in the HV circuit. They are both easy to fix if the person has some experience.
ATN Aries 390... | Answered on Nov 29, 2008
No more lights steady type: Aries 390 Paladin, light guide only focus.
ATN Aries 390... | Answered on Nov 12, 2008
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayn
ATN Aries 390... | Answered on May 31, 2008
I Have two Mk 6500 they are both pitch black inside. YES i put new battery in same thing. Is there a way I can fix this my self, they want $800.00 to fix one at ATN... these are not junk scopes..
ATN Aries 390... | Answered on May 12, 2008
yer its happened to me in button hole camera, cctvs etc it misses the metal guide so goes into casing and not card slot. need to open it to get it out
ATN Optics | Answered on May 04, 2018
ATN Aries 390 Paladin Weapon Sight Logo
17 questions posted
Top ATN Optics Experts
john h
Tom Chichester
Bill Boyd
Are you an ATN Optic Expert? Answer questions, earn points and help others
View Most Popular
ATN Optics
  • ATN Optics
Most Popular Question
nothing but pitch black
  • Optics
