20 Most Recent
Toshiba 55TL515U 3D LCD TV Questions & Answers
White screen on
The T con board or the LCD panel is faulty . You have to replace the TCON Board to confirm whether it was tcon or the LCD panel.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Tv grey screen
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
How do i change the fan in a 55TL515U TV?
Get a can of air and spray it directly in the back grill - at the bottom. the fan is very small and may be caked with dust. That was the issue with mine and the pressured air cleaned it right out and the fan began running again. Try this before calling for service - you don't even have to take the back off.
Picture freezes
Usually not the set causing this----a lot of times if a cable or sat box is being used it will act up and the signal will trigger the set to do odd things---only way to know is unplug set and box if used for a while and plug back---set not responding to the remote indicates a confused microprocessor.
Tv didnt have mounting screws
They can but you would either have to contact Toshiba (brand listed here) or Google the model number with something like "mounting bolts"
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
