20 Most Recent
Jensen JTA460 Turntable Questions & Answers
Blown speaker
Swap the speakers around to make certain it's the amp that causing the problem. Since stereo amps are two mono amps put together you have one good channel to compare the other one with. Sometimes a visual inspection will show what's wrong with it.
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
- Press and hold the "Time Set" button until the display flashes.
- Press the "Hour" and "Minute" buttons to adjust the time.
- Press "Time Set" again to confirm.
Jensen Compact Disc Music system JMC-500W. Open/Close button not opening the lid
Please hold down the open/close button instead of just pressing it. Then you can press the lid while this is happening. I think you might already suspect this, but it sounds like the hook that connects to a portion of the lid isn't unhooken during the button press. Friction might be a cause or the hook-movement might not be functioning as smoothly due to other factors.
If the issue continues, we might have to consult Jensen on a potential repair/replacement of the item as well.
