20 Most Recent KitchenAid KUDC10IXSS Builtin Dishwasher Questions & Answers
you must press the button and hold until the light comes on. if this doesnt work then there is a problem in the pcb and it will have to be replaced, which is costly, so look into an extended warranty first
KitchenAid... • Answered on Sep 27, 2013
Could be cycle timer failure
KitchenAid... • Answered on Apr 23, 2021
This appears to be a Dishwasher rather than the category 'Cell Phones', so I moved it and Edited your Question. Here is the answer for you. How to reset a Kitchenaid dishwasher? Cycle Reset If you just need to reset a cycle, simply press and hold the Cancel or Cancel-Drain button to reset the cycle and choose a new one.Apr. 20, 2018
The Reset Sequence for a KitchenAid Dishwasher ' Hunker
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00Z8bg7nFmtLavltrPr2TV9PXzEDw%3A1613419081369&ei=SdIqYLePFpGGsAXk04_4DA&q=kitchenaid+kuds02srss0+reset+button ..
KitchenAid... • Answered on Feb 15, 2021
As it takes a lot of energy to heat water, energy that would be impractical at 12 volts I am guessing the voltage should be the same as the mains supply, whatever that is.
KitchenAid... • Answered on Nov 30, 2020
Some dishwashers have a soft food disposal inside. If something is hung up, it will grind or hum for a long time. If this is the problem, it will eventually go away.
KitchenAid... • Answered on Jun 29, 2020
This could be the relay that controls the heating element, I dont see a separate relay so it may be on the main board. The relay could be stuck closed due to the high current that might have welded the contacts closed. It could also be a sensor issue that is closing that relay. The error code you listed says it is detecting cold water.
KitchenAid... • Answered on Apr 23, 2020
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there. Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
KitchenAid... • Answered on Nov 28, 2019
Pick any 3 consecutive keys (except Start or Cancel, then press them in the sequence 1, 2, 3, 1, 2, 3, 1, 2, 3. The dishwasher will go through a self-test and short cycle, and reset itself.
KitchenAid... • Answered on Oct 03, 2019
Sound like the is a problem with one of the supply pipes for the water check they are not blocked and the is no turn off on
KitchenAid... • Answered on Jul 06, 2019
There are several touch pad buttons that could activate the Child Lock feature on a Kitchenaid dishwasher. To toggle off the lock, try pressing and holding the 4-hour delay dry or the energy saver dry key pads for 4+ seconds. The Energy Saver Dry is used for the Child Lock on the Kitchenaid KUDS25SHWH1. This manual is here: https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L9050329.pdf . The 4-hour delay or Control Lock options are listed in this manual: https://www.kitchenaid.com/content/dam/global/documents/201605/owners-manual-W10596243-RevD.pdf . If neither of these steps work, you may have a problem with the keypad, the wiring between the keypad and the control board or the control board itself. Please add a comment with the model of the dishwasher if you'd like me to try and find the parts list/diagram. If the machine is under warranty, you may want to contact Kitchenaid. I hope this helps. Cindy Wells
KitchenAid... • Answered on Jun 30, 2019
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.Here's the solution:Put a towel at the bottom of each side of the door by the hinge.Push the door closed a couple of times to bend back the hinges.Remove the towels and you're back in action.Good luck
KitchenAid... • Answered on Jun 22, 2019
KitchenAid KUDC10IXSS Builtin Dishwasher Logo
9 questions posted
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
heat dry stopped working button still
  • Dishwashers
