20 Most Recent
Nokia 6555 Cell Phone Questions & Answers
Lcd screen removal broken
just go to the company of the phone , and they will put a new one for you , im just suggesting so just search it. and good luck
Master reset code for nokia 6555
Many of us believe that master can unlock security code but I don't believe and I never heard that they can fix with this code.As a mobile technician I advise you to visit mobile repairing shop.We the mobile technician use many varieties of repairing tools.We can reset it to default or we can generate the current code even you have modified.But it is up to you wish.
My lg 300 gb puk code is locked can you help me
A
request for a PUK code ("Personal Unlocking Key") will appear on your
phone if your SIM card PIN code is entered 3 consecutive times
incorrectly.
Your SIM card will then become
"PUKed" or Blocked. This is a security measure to protect your service.
You
need to call the Customer Service department of your cell phone
provider and they will give you the PUK code which will unblock your SIM
card.
Nokia 6555 forgot unlock code
Take the phone into your provider- they can sometimes flash the chip and get you going again. Good luck, and hope this helps.
My Nokia 6555 screen suddenly started showing
What this simply mean from this reaction of the phone, indicate that your phone has develop a flex problem connected to the screen.
What you are to do to fix up this problem, carefully unscrew the phone with screw driver (technician )place the screws in a ave place and than remove the case of the phone protecting the phone panel locate the screen connected with /to the panel remove the connector (flex) carefully then get a bettrer one from the store then replace it.
Note:make sure that the new flex i.e connector is as same brand of the old part that is same make for easy compatible.
With this the problem of the phone will be save.
Thanks.
Keeps turning off
hello , maybe your battery is loose , open the back cover remove the battery and tahe a small piece of paper fold it and insert it with the battery i mean bottom of the battery ,so that your battery fits tight , close the cover properly ,switch on your phon and check , 100% problem solved , regards.
Hi,The puk code is a code that is generated by the service provider for a specific sim card,that is why it is called "personal unlocking key"(puk) code.
Your puk code can only be obtained from your service provider,here is my solution;
Contact your service provider with proof of ownership of the sim card and request for your puk code,
The code will be given to you under few minutes for free.
Take care
Unlocking nokia 6555
There usually is a limit so it is best to just contact Nokia to have them provide you with the code. If you lock yourself out by trying more than the times allotted in a day then you can permanently lock your phone out on Nokia's end and on your cell phone companies end so its best to call Nokia and get the unlock code from them.
What is the passcode for a nokia 6555 to be paired
there is no code all you need to do is check the blue tooth settings and switch on the devise it automatically locate the other phones and you can pair them if it ask for a passcode type 00 and on the other phone type 00,that wil work out ,thnks .
Software problem Nokia 6555
Yes, it might help. You can also update the software version or the custom version. If you are doing the update by yourself, you want to be careful in case your phone freeze in the middle of the update process.
