20 Most Recent Toshiba Tecra R850 Series Black Notebook Computer R850S8530 Questions & Answers
3answers
How to rip a dvd
Handbrake is free and powerful. However, as for a novice, I prefer to the easy to use DVD ripper like Leawo DVD Ripper. And you can follow below steps to rip a DVD.
Load the source DVD file
With Leawo DVD Ripper running on, click "Add Blu-ray/DVD" to add DVD files or just drag and drop DVD files onto the Leawo DVD Ripper software.
Choose Output Format
Click the drop-down list named MP4 Video by default on the left of the green "Convert" button, and choose output video format. Note: The drop-down list is named MP4 Video by default, but if you have changed the output video formats into others, the drop-down list will display the according name. For example, if you have set MOV as output video format, you will see the drop-down list display MOV Video when you launch Leawo DVD Ripper again.
Adjust detailed settings
Clicking "Edit" to adjust video and audio parameters of output format, including: video codec, quality, bit rate, frame rate, aspect ratio, channel, audio codec, resolution, etc. Note: This step is optional. If you don't know the exact parameters to set, you can directly leave those parameters at default or just skip the step.
Start video conversion
Click the big green "Convert" button on the top-right of the interface to start the conversion. Before conversion, video saving directory can be chosen. blu-ray-ripper-import-nbxoe2gwzkiyrqitmph5sgwh-2-0_0.jpg For more details, check: Rip DVD to Computer
5/10/2019 3:42:37 AM • Toshiba Tecra... • Answered on May 10, 2019
Removal of supervisor passwprd
Remove CMOS battery inside of the motherboard and "short" contacts. wait about 5 minutes and replace battery. It should reset bios to factory status. Won't affect your operating system and hard drive.
4/25/2015 4:38:32 PM • Toshiba Tecra... • Answered on Apr 25, 2015
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
4/26/2014 11:47:57 AM • Toshiba Tecra... • Answered on Apr 26, 2014
Toshiba tecra r850 keyboard problem
Hi, make sure the drive keyboard is right and do the update, if problem persists have to replace the keyboard.
12/16/2013 11:50:09 AM • Toshiba Tecra... • Answered on Dec 16, 2013
Bios
It is not possible to change BIOS password, the one and only solution is to re-install the windows.
6/18/2013 10:59:10 AM • Toshiba Tecra... • Answered on Jun 18, 2013
0answers
2answers
Toshiba Tecra R85. CMOS battery location on it please?
is that a typo OP< R850 is it? use you tube, key word dismantle. or replace motherboard. see coin cell in the process. found it for you and is special battery rechargable it is, no CR2032 sorry R850 found it by pretending to buy the whole mobo. rtc-oiylrsmw3ek2y54ns2x2w4ad-d-0.jpg see the red x, it is bundle of batteries like this using the wrong battery it will explode, the users guide said that . and will.
4/17/2024 5:31:13 PM • Toshiba Tecra... • Answered Yesterday
Built in hdd error
remove the hdd and attach to desktop . right click in my computer and run check disk in tools section in drive properties
9/25/2017 2:24:55 PM • Toshiba Tecra... • Answered on Sep 25, 2017
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery. 2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
9/25/2017 2:23:22 PM • Toshiba Tecra... • Answered on Sep 25, 2017
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
9/25/2017 2:11:33 PM • Toshiba Tecra... • Answered on Sep 25, 2017
My phone is not turning on
I have had this on an iphone 5. Apple sold me a new phone as it was not worth repairing and it was out of the 12 month warranty. Its possible to order a new part and do it yourself but unless you are totally confident and have the skills to open up your phone and reassemble it then its just not worth it.
4/18/2015 7:39:49 AM • Toshiba Tecra... • Answered on Apr 18, 2015
Change settings quick launch button
What is the actual question?
2/2/2015 9:15:20 PM • Toshiba Tecra... • Answered on Feb 02, 2015
Tecra s10 display brightness
look closely at the keys along the top of the keyboard (usually called F keys). one of them should have a tiny sun icon and the key beside it will have a larger sun icon. hold down the "Fn" key elsewhere on the keyboard while pressing the one of the sun icon keys to brighten or darken the picture. the sun icon keys may also be located on the Arrow keys (<-- --> etc.)
1/31/2015 8:20:14 PM • Toshiba Tecra... • Answered on Jan 31, 2015
Toshiba Tecra R850 Series Black Notebook Computer R850S8530 Logo
Popular Tags
10 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Tecra Toshiba
  • Tecra Toshiba
Most Popular Question
rip dvd
  • Computers & Internet
