20 Most Recent
LG DLE2140W Dryer Questions & Answers
Why won't dryer heat
You will have to remove the power cord from the mains supply.
There are four reasons for this problem:
1. Thermal fuse
2. Heating element
3. High limit thermostat
4. Main control board.
The main control board does not usually give any problems but it cannot be ruled out. Have someone knowledgeable about electrics check out the above.
Dryer trips breaker after only a few mins of operation
Check to power at outlet for 220 volts
Check the breaker for the correct amperage cut off.
If the unit had an obstruction in the air flow, it would not trip the breaker.
Try running the unit with just cool air and see if it trips the breaker.
Odds are, you have a defective breaker.
Also, if the home is newly built, check the panel for loose connections at the breaker.
Or you could try a different power outlet, like the hot water heater.
If the unit continues to trip breakers on other outlets, you may have a short in unit.
Drum wont stop
If you checked the heating elements you should have see an envelope that is enclosed in the machine. It has all the diagnostic information and tests that techs use.
Dryer is humming when off
if it works fine then dont worry its normal.and if u need to solve the problem u have to replace door seal and belt.
Thermal fuse located
It is located on the side top of the cover of heater element. Part number is 6931EL3003D
