20 Most Recent
Samsung Galaxy 551 Cell Phone Questions & Answers
How do I backup my phone?
That depends on the phone. Android, try:
http://www.gottabemobile.com/2014/03/29/how-to-backup-android/
Text receive
You can check settings for your messages,see what you have selected.
Forgot pattern lock
Give it a try:
- Apply wrong pattern for sometimes
- When it exceeded the limit it display "enter your email and password"
- Put your email and "NULL" in password field
- This will ask you new pattern lock
Samsung galaxy 551 camera is locked how do i unlock it
Here is your solution. I too had the exact same problem and I found your inquiry and the solutions above will not work period. I felt kind of stupid once I actually stumbled on the solution and it's quite simple. Open your camera, and I know it won't be responsive to your touch- what you have to do is press both volume button AND power button at the exact same time, I pressed volume down button, and the lock icon disappeared and I was able to finally access my camera to use. No complicated answer at all and I'm shocked there was virtually nothing online to suggest a solution. THIS is the solution- stupid simple right? If you press the volume button again with power button the lock will be activated again.
Screen does not turn on
Dear My Brother:1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
Can't recieve text messages
hey its easy,first install the app "app2sd"then check the available space in deviceif it is below 20 mb u cant recieve messagesfor solving this problem uninstall some apps installed in phone memory....
