20 Most Recent Bronica SQ-Ai Medium Format Camera Questions & Answers
Camera cocks but will not
Is there film loaded? Bronica cameras feature an interlock that will prevent the camera from fully firin when not loaded, when no back attached, or when the dark slide is in the back. Some models have a small flip-switch that doubles as a double-exposure switch on the side that can be used to dummy fire the camera to test fire it.
If that doesn't work, consult a tech. The electronic's in these cameras go bad qute often these days.
9/4/2011 3:41:50 AM • Bronica SQ-Ai... • Answered on Sep 04, 2011
Non availability of LR 44X4
They are still easily available online.
Here's one supplier that I regularly use. Even if the supplier is no use to you, you'll see the many other model numbers for the same battery.
8/18/2011 12:47:28 AM • Bronica SQ-Ai... • Answered on Aug 18, 2011
Format nokia 6030 mobile
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
5/30/2010 4:09:59 PM • Bronica SQ-Ai... • Answered on May 30, 2010
Bronica SQ A The plastic 'double exposure' lever
I doubt if you will find a suitable material unless you switch to making one out of metal. Brass would be my choice.
12/7/2009 11:43:21 PM • Bronica SQ-Ai... • Answered on Dec 07, 2009
Bronica SQ-Ai shutter problem
There could be a number of issues with this problem. Make sure the contacts at the rear of the lens and those on the body that connect with those on the lens are clean and straight. If so, the problem may be in the shutter within the lens. There is a magnet inside the shutter that sometimes becomes contaminated and fails to hold the shutter blades open for the selected shutter speed. The face of the magnet may need to be cleaned. There are also timing switches that sometimes go bad or need adjusting. These internal problems need to be taken care of by a competent technician since the lens needs to be completely disassembled. I have also seen these shutters go bad and need to be replaced. Let's hope that's not the problem because it will be difficult to get a new shutter for the lens--but not imposible. God luck.
4/9/2009 4:52:32 PM • Bronica SQ-Ai... • Answered on Apr 09, 2009
Bronica sq-b, mirror lock up lever was broken
Hi, I have the same problem - my lever plastic become broken in 2 days after I'vet body from KEH. Seems that iron topof the lever can be screwed in counter clockwize direction and after new one lever installed it can be screwed back and fixed with rubber cap.
But question to you - where did you get the replacement?
You can contact me on [email protected] at any time.
Regards,
Kirill.
12/24/2008 6:59:28 PM • Bronica SQ-Ai... • Answered on Dec 24, 2008
Shutter will not cock
Hi there
I have researched your problem. I have located the online version of your camera and attached the link here:
http://www.tamron.com/assets/pdfs/SQ-A.pdf
It seems like the following cause might fit your symptom:
Is it possible that the small lever on the side might be set to multiple exposures. (See number 22 on the online manual that I sent the link for!)
Good Luck! and let us know how this works.
1/4/2008 11:59:48 PM • Bronica SQ-Ai... • Answered on Jan 04, 2008
Need digital back for bronica
Here are some sources:B&H:buycheapr:
2/20/2012 7:32:33 PM • Bronica... • Answered on Feb 20, 2012
Need a manual for an Aluratek 8" Digital Photo Frame, model ADMPF-108F
Google it
12/21/2021 9:17:58 PM • Photography • Answered on Dec 21, 2021
2answers
Can photos already on the device be removed?
We offer professional SEO & digital marketing services to Spokane WA & Coeur d'Alene ID, since 2009 Website: https://spokane-seo.com
11/27/2021 6:52:10 PM • Photography • Answered on Nov 27, 2021
How do I turn the miranda 750 tripod into portrait view? If possible.
On the top section of the tripod where the camera sits there are three adjusters that unscrew to loosen and screw in to tighten. There are Two 'Twist' nuts and One longer silver and black handle. The long handle when twisted adjusts the Up/down angle. The twist nut that is positioned lower down controls the left/right movement. The twist nut you are looking for is the one positioned at the highest point. When loosened it will tilt between portrait and landscape. Sometimes if the tripod has a 'quick release' plate the camera can be accidentally mounted a quarter turn too far left or right. This means the 'portrait' adjuster can be mistaken for the Up/down adjuster.
11/26/2021 2:40:39 PM • Photography • Answered on Nov 26, 2021
2answers
Mag edit ng picture
Hi Eldrien, There are several ways on how to edit a picture . I t depends on what you want to do with the picture . If its just for basic editing you can use MS Paint ( https://www.youtube.com/watch?v=QjRi0Mq3G2g) or using more advance softwares like "photoshop" (https://www.youtube.com/watch?v=o-u-OYz2qaU) I hope it provides you an idea. Thank you. Dennis
11/15/2021 3:04:52 AM • Photography • Answered on Nov 15, 2021
Driver for target australia film scanner f100
I own the Target AU F100 film scanner and have the original CD. It has a Driver directory on it, which includes DriverInstaller app and 32 and 64 bit subdirectories. It installed recently on my Win 10 64 bit PC and worked ok, despite being Win XP/Vista software vintage 2010.
10/26/2021 5:19:34 AM • Photography • Answered on Oct 26, 2021
Where can I find a manual for a 7" Omnitech Digital Photo Frame that I bought at a second hand store? mdl # 18676-CA, 480x234, serial # SUCA700CI09d01245.
Contact Omnitech directly to inquire and/or do a Google search for the product
7/24/2021 3:16:50 AM • Photography • Answered on Jul 24, 2021
9answers
Easycap USB 2.0 Capture Controller HELP!!!
You will need to download
XP - http://www.vidblasterus.com/Drivers1150.zip
Vista - http://www.vidblasterus.com/Drivers1160.zip
You must then plug in your device. Then go through the driver update it will say cannnot find and ask if you have a disk click I dont then click browse my pc for drivers. open the zipped folder and extract all the files onto your desktop. Then just select desktop in the driver update and it will install :DD
7/14/2021 3:28:51 PM • Photography • Answered on Jul 14, 2021
I have a Cosco folding chair with tag on bottom saying Cert. of Quality FL-FQC. Then another sticker 14-875-SDN Fan Bk Chair Bar code 0 44681 14715 9 dated June 11, 1999.
What, exactly, does this query have to do with photography ? I am agog with anticipation to discover the answer.
6/11/2021 3:18:55 PM • Photography • Answered on Jun 11, 2021
Pandigital frame. Why isn't it working?
That is indicative of a power issue. Battery is not holding enough power to stay on.
5/21/2021 4:23:44 PM • Photography • Answered on May 21, 2021
Bronica SQ-Ai Medium Format Camera Logo
9 questions posted
Top Bronica Photography Experts
Tony Parsons
Tony Parsons
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Bronica Photography Expert? Answer questions, earn points and help others
View Most Popular
Bronica Photography
  • Bronica Photography
Most Popular Question
camera cocks but will not
  • Photography
