20 Most Recent Bronica ETR-Si Medium Format Camera Questions & Answers
2answers
Battery
dear choirboy,
the accepted battery models for the bronica etr-si are 4LR44 and/or 4SR44.
Sincerely,
Agent Allan
Go Ahead. Use Us.
2/9/2021 11:24:52 AM • Bronica ETR-Si... • Answered on Feb 09, 2021
My phone is not format nokia 5610 [*#7780#]
This is not a Bronica ETR question.
2/3/2019 3:03:07 PM • Bronica ETR-Si... • Answered on Feb 03, 2019
Bronica AE II E Finder Owners Manual
Since I never use a TTL flash with my Bronica's, I'll give you my suggestion for a great solution. Using your TTL Metz flash, (make sure you've connected the TTL cord for Bronica ETRsi) take 8 shots at different apertures on A (Automatic), then take 8 shots at different apertures on M (Manual). I realize this will waste one 120 roll of film, but one negative will stand out as your perfect exposure. Yes, whenever you reduce the ISO in half, your basically overexposing the film by one f/stop. Just remember that this overexposes everything your shooting from foreground to background. With flash, this may cause your highlights to wash out, but any good lab could print for the highlights and make the background go darker. I used to shoot Vericolor at ISO 125 instead of it's rated ISO of 160.
Fotobean
1/30/2019 9:20:45 PM • Bronica ETR-Si... • Answered on Jan 30, 2019
I want o buy one in ex condition a waistlevel
Hi Lindsay , if you search in ebay you can get it from there.
2/1/2011 9:49:04 AM • Bronica ETR-Si... • Answered on Feb 01, 2011
The shutter seems to only have one speed. New
Well, if you don't have film in the camera it will only operate at 1/500 sec shutter speed. I hope this solves your problem.
1/31/2011 5:40:24 AM • Bronica ETR-Si... • Answered on Jan 31, 2011
I need a manual for #rf645 bronica camera
http://www.butkus.org/chinon/bronica/bronica_rf_645/bronica_rf_645.htm
11/27/2010 6:54:27 AM • Bronica ETR-Si... • Answered on Nov 27, 2010
Wanting to purchase Focus screen for Zenza Bronica
Keep an eye on ebay as they appear on there occasionally. However, you can't always get exactly what you want and it took me a while before I could find a split image version. All you have to do then is win it!
10/6/2010 9:18:15 AM • Bronica ETR-Si... • Answered on Oct 06, 2010
Hi, I have a set of
Sorry Sam, but there isn't one. I just shoot on transparencies (Fuji Velvia 100) and then scan them to obtain digital images.
Transparency film isn't cheap, and even less so with wasted shots, but it's still cheaper than the
9/21/2010 9:54:12 AM • Bronica ETR-Si... • Answered on Sep 21, 2010
Had camera in damp basement. Mold got between lens
the best thing to do it drop this camara into a shop for them to fully service it you will never get all the mold spors out of it now
3/29/2010 8:35:41 PM • Bronica ETR-Si... • Answered on Mar 29, 2010
Shutter stays open
You might have the lens set to 'T'. Check that lever on the lens barrel
12/7/2009 10:58:52 PM • Bronica ETR-Si... • Answered on Dec 07, 2009
ETR film counter resets mid roll when shutter is depressed.
Hello. 35mm cameras back in the day used to suffer from this irritating problem. There is a small button that is pressed by the door edge when you close the back. Due to age(flexing and slop) that occurs with normal wear, the metal edge becomes ever-so-slightly bent, resulting in a less-than-needed pressure on this button. The button, when held properly by the back, captures a little internal gear mounted on the film counter dial--preventing its spring-loaded return. When you remove the back to re-load film, the counter immediately jumps back to "start". As the film advances, the roll increases in size and pressure against the door, causing the symptom. Go to a camera store with knowledgeable sales people and you might find one who knows how to re-work the back just-so to fix it. To be absolutely sure, however, you'll need to buy another back.
On some medium-format cams, there is a little raised "bump" on the edge of the door that precisely matches up to the position of the button. If this is the case, and you are careful, it can be gently but firmly squeezed to make it stick out more, increasing the pressure on the counter button.---Rick
9/17/2009 5:49:53 AM • Bronica ETR-Si... • Answered on Sep 17, 2009
Which 120 backs & lenses for my ETRSi do I buy?
All ETR backs work with all ETR cameras except the ETR-C, which only uses the inserts. The early backs have a single latch and a winding key. The middle ones have double latches and a winding thumb wheel. The Ei backs have double latches and a winding crank like a 35mm has. The Ei backs also have a locking dark slide to prevent accidental film exposure wnen the back is off the camera. All inserts work with all the back frames. I the used market you will find them in any combination (frame, insert & darkslide).
I am aware of three series of lenses: MC, EII and PE. They all work fine with any body.
7/5/2009 10:25:16 AM • Bronica ETR-Si... • Answered on Jul 05, 2009
3answers
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
7/5/2009 6:58:38 AM • Bronica ETR-Si... • Answered on Jul 05, 2009
2answers
Don't know how to take off the manual film crank
If I remember correctly you pull out the pin that the crank swivels on.
6/23/2009 6:24:19 PM • Bronica ETR-Si... • Answered on Jun 23, 2009
Battery problem with ETRS
On the AEII Finder, there are four contacts on each side of the finder and also the ETRsi body. Clean the contacts on both sides and see if this helps. Another test to see if it's getting voltage from the battery is on the body contacts(on top of the body where the viewfinder slides on). Take a multimeter (any multimeter) and touch the ground (black) probe to any place on the body except the contacts and touch the positive (red) probe to each contact on the body and see if there is battery voltage anywhere. If you get voltage that's close to the 3 volts from the battery, then it's good. If not, there is a circuit break between battery & body and this requires a repair shop because the camera would need to be stripped down to locate the problem. Be aware that the body battery supplies voltage to the Seiko Electronic shutter and the AEII prism. Hope this helps.
1/21/2009 12:48:28 AM • Bronica ETR-Si... • Answered on Jan 21, 2009
Manual
Hi Choirboy, you can download the manual here:
PART ONE HERE
PART TWO HERE
4/6/2008 12:21:32 AM • Bronica ETR-Si... • Answered on Apr 06, 2008
120 film backs
skip frames or overlapping(multiple)exposure is caused by the film advancing mechanism. if you treasure your camera y back. send it for service.
pc-cook
1/26/2008 6:17:54 AM • Bronica ETR-Si... • Answered on Jan 26, 2008
Bronica ETR-Si Medium Format Camera Logo
Popular Tags
27 questions posted
Top Bronica Photography Experts
Tony Parsons
Tony Parsons
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Bronica Photography Expert? Answer questions, earn points and help others
View Most Popular
Bronica Photography
  • Bronica Photography
Most Popular Question
shutter stays open
  • Photography
