20 Most Recent
Toshiba M200 Tablet PC Questions & Answers
BSOD
I found this on the web. pls read below
If you find this information, helpful, pls rate
me. Good Luck.
In most cases, the build up of junk files in your registry is the main culprit of this trouble; this is due to the fact that area in your computer is very crucial because it is the central database of important files where most vital information and programs are stored. The accumulation of redundant items can significantly affect vital data because the build up can dislodge some of them from its proper location and cause others to be corrupted. The moment this scenario takes place, problems start to emerge and the dreaded blue screen of death appear which you need to immediately repair to prevent worsening the case.Consequently, one of the best solutions in managing the situation is to use registry cleaning tools http://make-computer-run-smoothly.com with great power and capacity to completely flush out all junk files and fix all errors found. By effectively keeping this area clean from all trashes, you can also effectively solve the problem and even optimize your computer's performance.
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
