20 Most Recent WAYN.com WAyN Questions & Answers
i cant login into skout on my computer
WAYN.com WAyN | Answered on Sep 03, 2012
I have been Block and i want to join Wayn again, so what should i do Please guide me to reconnect now.
WAYN.com Android... | Answered on Mar 31, 2014
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Android Apps | Answered 19 hours ago
reboot your phone,when it starts to turn back on hold down volume down poer and home keys until you see a arrow coming out of box by android guy.let go of buttons then push the serch button.then use volume down scroll down till ur on reboot and push your camera button that should fix ur problem.
Android Apps | Answered on Jul 28, 2020
on a Samsung phone Goto:
Settings>Applications>All Applications>Call>Call accessories>uncheck Automatic Answering
Samsung Galaxy S5 How to enable or disable Automatic answering Android...
for other Android devices:
https://www.youtube.com/watch?v=G-ezpxQuMvw
Android Apps | Answered on Jul 14, 2020
Follow this for Android:
  1. Open settings.
  2. Look for Installed Apps.
  3. Tap on Flipkart App.
  4. look for "Clear Cache" and tap on it. (You browsing history will be deleted)
  5. If you want to clear data, you can clear the data as well. Only problem with this is, you will need to login again the next time you open the app.
https://www.quora.com/How-do-I-delete-the-Flipkart-browsing-history
Android Apps | Answered on Jul 12, 2020
Download an application named "Android Download Manager" and keep the app open, In most of the cases the application will automatically detect the file and will pop up on the screen, Otherwise copy the download link and paste it in Android Download Manager and you can download it in high speed with resuming capability.
Check for intake air leaks including via the brake servo and other vacuum hoses, check the idle air valve and throttle body for correct operation and cleanliness, check the egr valve and ports, check the purge valve and hose...
Android Apps | Answered on Jun 20, 2020
If you mean the Google Play Store, you can download the .apk file from sources such as
http://earth.androidapksfree.com/venus/com.android.vending-v5.4.12-80341200-Android-2.3.apk
(find links for the latest version at http://www.androidapksfree.com/apk/google-play-store-apk-latest-version-download/ )... then transfer it to your device using a USB cable connected to your computer (put it in the Downloads folder).
In your device's Settings, go to Security, then put a check next to 'Unknown Sources' which allows apps to install from a local .apk file. Next, use the MyFiles app to go to Recent files. Find the com.android.vending-[version].apk file, click on it, then follow the prompts to allow it to install.
Once it's finished installing, go back to Settings->Security and UNcheck the Unknown sources option again (you don't need that checked to install apps from the Play Store).
Android Apps | Answered on Jun 05, 2020
No.. in all my many years (since the first release of Android in 2008), I have never had any problems with Malware, Viruses, Trojans, hacking, etc on an Android phone or tablet. It may be possible to hack someones Android phone, but you'd have to be a celebrity to make it worthwhile for someone to do that. It would be a big waste of time for most average people to target someone like that.
Googles Android security chief Dont bother with anti virus Is he serious...
Android Apps | Answered on Jun 03, 2020
its made for skype f.e. skype forced you using android, simbian and so on they try to - get everybody there you simple have to get back where everything come from
Android Apps | Answered on May 29, 2020
Tip
How to Download Videos directly into Android Smartphone
YouTube videos are a great way to pass the time. If you are with an android smartphone then you can also directly download youtube vides with TubeMate YouTube Downloader app on your phone and watch them even when you don't have access to internet. We have tested this app on our Samsung Galaxy s3.
Features
The App Home consists of the usual YouTube mobile view with search function and buttons for home, categories, live, favorites, playlists, subscriptions, My Videos, inbox, history, settings, and the option "Add TV".
From menu button it is possible to switch from Mobile view to desktop view.Moreover, here most of configuration options can be found like empty the Cache, settings for the fast downloads, language, region and notifications, and set the download folder for videos and MP3 audio tracks.
There is also an option to change home screen to "Offline Home" instead of online TubeMate view. This provides direct access to the folder with the previously downloaded videos. Videos can also be added into the app via playlist and can be shared on social networks. If you are low on internal memory then you can change the default download folder to SD card.
Depending on the quality of the original video, the selection of various download formats and resolutions are possible (see screenshots). You can also choose to download only the video in MP3 format.. These choices are also beneficial if you don't downloaded video but watch them online, for example, if you have low bandwidth of Internet connection or rather weak hardware.
Several videos can be simultaneously added into queue and they will be downloaded in order.
Operability
TubeMate is very simple and intuitive. In contrast to the download app "TubeGod" it has can also be supports other languages like German and Spanish.
Downloaded videos get stored on the default folder for easy retrieval. The video was viewed even at the highest resolution video without any problems. On android phones with weaker hardware it is advised that videos should be watched at a lower resolution. There were no crashes during the test on Samsung galaxy s3.
To dowload Tubemate Youtube downloader just click on the link below.
Downloading TubeMate YouTube Downloader 2 2 5 636
on May 28, 2020 | Android Apps
Tip
Hire Top Mobile App Developers
The world has seen phenomenal growth in mobile devices and their usage around the world. The form factor has reduced, but the computing power has grown many folds. OTS Solutions has worked in past decade amassing great talent pool of world class mobile app developers in platforms and devices like iOS, Android, Windows, iPhones, iPad, Tablets etc.
OTS Solutions with time and experience, has optimized its internal hiring processes with stringent guidelines and parameters to hire only top quality engineers. Our top mobile app developers come from a wide array of industry skill set with technologies spread ranging from native styled objective-C, Java, Swift, Kotlin to cross platform technologies like Ionic, React-JS, Titanium.
Hire Top Mobile App Developers Hire Mobile Engineers
on May 15, 2020 | mobile developer Android Apps
Fix Error Code 504 While Downloading Apps On Android, follow these steps , Visit URL and Find Solution : https://www.errorcodeexpert.com/how-to-fix-error-code-504-while-downloading-apps-on-android/ or call us : +1-866-748-5444
Android Apps | Answered on Apr 15, 2020
WAYN.com WAyN Logo
2 questions posted
Top WAYN.com Apps Experts
Marvin
Marvin
ray gallant
Are you a WAYN.com App Expert? Answer questions, earn points and help others
View Most Popular
WAYN.com Android Apps
  • WAYN.com Android Apps
Most Popular Question
account lying suspended 6months
  • Android Apps
