20 Most Recent
Toshiba Satellite 4300 Notebook Questions & Answers
Where are my settings? wireless network on 4300 series.PLEASE HELP ME!
You need to post more information on your laptop. What operating system is on it? Try tapping the F8 key when the computer is booting up to get it into safe mode and if you can get to safe mode then you can go to the system utilities and into the restore/backup menu of system tools and then restore the computer back to the last known good working point. You would then need to re-install the driver disk for the wireless and start again from there. Just pressing any old key in hopes of finding a solution is always a bad idea. So, post some more information about the operating system installed please. Dennis
4/15/2017 12:58:46 AM •
Toshiba...
Answered
on Apr 15, 2017
How to factory reset Toshiba
connected with the customer
customer wants to restore the computer from the factory default state (WIN XP)
tried doing F12 or pressing 0 key to trigger the restoration drive but to no avail
cx has a recovery disk but its windows 98
informed customer that the original software that came with the computer is Windows 98 since all of his disk there the refer to toshiba is for windows 98
someone might have upgraded the OS to windows XP
cx ok to use windows 98
was able to boot the computer using the recovery disk and now on the process of reformatting the drive and installing windows 98
End of call
If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
9/16/2011 4:13:50 AM •
Toshiba...
Answered
on Sep 16, 2011
Dvd drive not recognized by system
Make sure drive is seen in BIOS, if not, re-seat the drive. If still not seen in BIOS reset defaults and check again. If still not seen, replace the drive.
If the drive is seen in BIOS, then use the following to resolve.
http://www.fixya.com/support/r3688895-cd_rom_or_dvd_drive_not_seen_in_windows
6/19/2010 5:29:55 PM •
Toshiba...
Answered
on Jun 19, 2010
Toshiba system restore help please awhyaah?
- Hi, these are instruction to perform the System Restore; follow them carefully! You will need Disks (CD or DVD); only if you needed to Backup System Files, before restoring the system; in which you may be (prompt) to do so. So have available beforehand, at least 7ea, of (DVD-R), or (DVD+R), or (DVD+RW) @ 4.7 GB ready! *Note: It is important to make, Recovery Disks for the Computer as well, in the event of system failure! *System Restore: 1. Go, to: Control Panel 2. Click, on: System and Maintenance 3. Click, on: Backup and Restore Center 4. In the (left) Tasks area, click on Repair Windows using System Restore 5. Windows may take up to 5Mins, to Setup a Restore Point; be patience! 6. The restore Wizard 7. Use (Recommended) Restore Point. Be patience! your Computer will Shutdown, and Restart. *Note: Once the computer returns to Windows Desktop, do not perform any tasks, for at least (45 min) the System Restore is still running! *Conclusion: "Message successfully restored, or failed to complete restore? Follow “prompt message,” for further recommendations." "Helpful Ratings Feedback is appreciated,thanks paul7of9”
5/31/2010 1:17:37 PM •
Toshiba...
Answered
on May 31, 2010
MY toshiba 4300 was working untill i tried to
Hi, yes. Download a program called ERD Commander 2008 or 2005 and make a bootable CD. I think you will download an ISO so you need Nero to burn it on a disk. Then boot from it (on the toshiba 4300) and once you are using the ERD commander, look for system restore, and it's the same as the Windows system restore. Choose a day before you downloaded the Internet Explorer and see if it works. I hope this helps. Don't forget to rate and provide positive feedback
for our fast-free response today. Thank you :D
4/29/2010 8:14:47 PM •
Toshiba...
Answered
on Apr 29, 2010
Usb not aktif
verify that usb port is enable or disabled in the device manager.
my computer->properties->hardware->devicemanager
7/29/2009 12:21:53 PM •
Toshiba...
Answered
on Jul 29, 2009
My screen is durk
have a problem with LCD like, if you do not continue to
deteriorate, it is using CRT / LCD monitor with external
7/20/2009 4:47:37 PM •
Toshiba...
Answered
on Jul 20, 2009
Pci.sys
ya you can transfer that file but it is difficult as usual... you need to some dos and using this dos windows you can copied that file into your c: drive...
but i suggest try to repair with any xp cd
3/30/2009 6:52:29 AM •
Toshiba...
Answered
on Mar 30, 2009
Toshiba satellite m 70 series
Was it replaced with the same model graphics card? It sounds like a corrupt driver install. Try uninstalling and re-installing the graphics drivers. Sometimes it is necessary to run a utility like RegCure to clean up the registry after the old driver uninstall.
7/31/2008 6:45:48 PM •
Toshiba...
Answered
on Jul 31, 2008
Sound problem
Windows XP questions and answers
CH000647, How do I
install Microsoft Windows
XP. CH000661, How to clear Microsoft Windows
... CH000857, How do I play a
sound or music file in Windows?
Installing a computer sound card.
Use this software to
install the card into the computer.
Sound card drivers can be found on our
sound card driver page. If you do
not know the manufacturer.
Device Manager information and help
CODE 24 - Device
not Found, This device is either missing or
not working properly. Verify you have the latest driver
installed for your device.
Good Luck, Please dont for get to Vote/Thank You.
12/22/2007 8:41:05 PM •
Toshiba...
Answered
on Dec 22, 2007
Toshiba satellite goes dead
Assuming this is not hibernating and your harddrive is not set to shutdown after a certain idle time, it could be this is an overheating problem.
Check that the extraction vents are'nt blocked and that the fan area is well ventillated.
If necassary gently hoover around all ventillation slats.
Some laptops have the ability for the user to turn off the fan for certain usage, just check in your management settings that it's turned on, unless you know it is on' and it cuts in or stays on.
1/10/2007 11:52:41 AM •
Toshiba...
Answered
on Jan 10, 2007
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
