20 Most Recent
Toshiba Tecra A2-S336 Notebook Questions & Answers
Audio driver link needed
Hello rye2222, If your Toshiba has the Sigmatel Stac 9750TG audio chipset and Intel 855GM mainboard chipset, then try the link below to download the audio driver. Toshiba has no drivers on it's site for your notebook, but this is for another notebook that has the same chipsets. Hope it helps! Hal
http://cdgenp01.csd.toshiba.com/con...
No power?
take out battery turn on unit if you get no power its one of 2 issues either the power connection to board or adapter try adapter 1st then if it doesn't start you may have more serious issues start shopping oh yea could also be a bad ram simm
Toshiba tecra a2 screen backlight problem the is
screen not lighting up is either the screen inverter or a broken tube inside the screen. Tubes don't break by themselves so a dim screen usually comes after a transport or a drop. I would replace the inverter first (just cause it's easy and cheap). eBay's a good source for inverters and screens and you ought not pay more than $5 for a used inverter and anything more than $30 for a used screeen would be considered tourist price. Tecra A2's are rare, but it's the same as the more popular Satellite A55's. Its screen should be a 15" XGA and would be the same screen as many other Toshiba Satellite models (A10, A15, A40, A45, A55) and Satellite Pro models (M10, M15), to name a few.
In my opinion, dim screens are 98% broken tubes and 2% inverters.
Need a nic driver for
Depending on what operating system you are trying to find network card drivers for, this site should provide you the drivers needed.
http://www.intel.com/support/network/sb/cs-006103.htm
Make sure to download the drivers appropriate for your operating system (i.e. Windows 200, Windows XP, Windows Vista, Windows 7)
Good Luck! Thanks for using FixYa!
Toshiba tecra a2-s336 driver for
Always
get your drivers and specific software from the manufacturer of your
Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the www.toshiba.com
web
site,
usually one is able to download if available, by model
number,
All
available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing.
This is the best way of ensuring up to
date drivers for your system and they are free of charge!
I hope this helps.
Sound Driver for A2 S336
You can get it direct from Toshiba below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Drivers
how did you get here,?,go to the support site download the drivers (save) to desktop,burn them on data cd,or drag onto flash drive,then put it in the toshiba
Toshiba Tecra R85. CMOS battery location on it please?
is that a typo OP< R850 is it?
use you tube, key word dismantle.
or replace motherboard.
see coin cell in the process.
found it for you and is special battery rechargable it is, no CR2032 sorry
R850 found it by pretending to buy the whole mobo.
see the red x, it is bundle of batteries
like this
using the wrong battery it will explode, the users guide said that . and will.
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
