20 Most Recent
Toshiba Portege M200 Notebook Questions & Answers
How to have dual hard drives in Centro laptop?
You can't actually put one inside however you can add one either by USB or Firewire ports. Therea are many USB hard drives out there, you simply plug into the relevant "Port"and use as normal.
How do I preload a harddrive?
Hi sarahabigail, when you first buy a computer, there are preloaded Software Programs in the (HardDrive), most of the Software is (Set) on your Desktop when you first setup the initial Start of your computer. These (Programs) need to be setup; you can Right click on a Program Icon to: (Open It), follow the instructions to Install the software; so that it will be prepared for use. Thanks paul7of9
Driver
hi,
you can download thed rivers from http://notebook.driversdown.com/notebook-drivers/s_685_1.shtml.
Thanks
Dead Pixel in Toshiba Porteg? M600 laptop
Without rplacing the main part of the lcd, I'm afraid you're stuck.
Nice laptop. Toshiba service has always been reasonable in my experience.
Sorry I couldn't offer better advice.
Good luck
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
