20 Most Recent Toshiba Toahiba Satellite A70 A75 M35 Series 15.4 WXGA LCD Display Samsung LTN154X1-L03-K000016010 PC Notebook Questions & Answers
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Toshiba Toahiba... • Answered on Dec 31, 2009
Just restore your system from a backup taken before the error code started. If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
Toshiba... • Answered on Mar 19, 2020
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
Toshiba... • Answered on Mar 11, 2020
dvd players play vob or mp4 format. so try "convert x to dvd" software to burn your dvds in the right format http://www.vso-software.fr/products/convert_x_to_dvd/
Toshiba... • Answered on Feb 16, 2020
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk. The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: - www.dvdfab.com/products,free.htm
Toshiba... • Answered on Dec 05, 2019
Hello,Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it. You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer. Davidhttp://goo.gl/CxsY9u
Toshiba... • Answered on Sep 25, 2019
Hello, to get the driver for your Toshiba, follow the steps below: go to http://support.toshiba.com/drivers enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well. Good luck.
Toshiba... • Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... • Answered on Sep 06, 2019
toshiba satellite error 0xc000021aBlue screen
Toshiba... • Answered on Jun 21, 2019
go to your browser proxy setting and make the proxy automatic
Toshiba... • Answered on May 21, 2019
check the power ic of the laptop with laptop technicians
use VLC it plays everything it even has extensions like subtitle downloader. VideoLAN Official page for VLC media player the Open Source video framework
Toshiba... • Answered on Apr 29, 2019
Take another video and don't drop your gear. The mishap obviously ruined the original.
Toshiba... • Answered on Apr 02, 2019
Remove the battery and see if it starts up fine, if not then try the following: 1. Unplug your charger cord. 2. Remove the battery. 3. Press and hold the "Power" button for 30 seconds or longer 4. Now plug back in the power/charger cord. 5. Now put the battery back in. 6. See if it starts up now, laptops often get stuck in hibernate mode.
Toshiba... • Answered on Nov 13, 2018
Follow the procedure: Device Manager USB Root Hub (USB 3.0) Change driver, manually, to "Generic SuperSpeed USB Hub" Now the hardware is working Upgrade the driver again, automatically
Toshiba... • Answered on Sep 25, 2018
  • The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out. Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity. After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computericon1.png, ideally, should no longer ask you for a BIOS password. It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password.
  • If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computersicon1.png that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Toshiba... • Answered on Sep 23, 2018
Computers & Internet Logo
1 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba lcd series 6 18 month old tv
  • Computers & Internet
