20 Most Recent Toshiba Tecra 740CDT Notebook Questions & Answers
windows 95 PC wow page 136.in all cases, all 3 batteries will be no good after 23 years. sorry, batteries are weak technology unlike chips inside PC that can go 100 years, some even 200. (facts)the top age failures are1: battery. all 3 in this case.2: CCFL lamps dead. or acting UP.3: HDD dead or growing bad sectors every hour. doom city! quote: 1995 740a-itglxzpxlmpuoy1xhsqbe4b1-2-0.jpg page 2: 740-itglxzpxlmpuoy1xhsqbe4b1-2-2.jpggood luck
Toshiba Tecra... • Answered on Nov 25, 2018
Sounds like the back light on the screen has gone, can be changed by someone who knows that field
Toshiba Tecra... • Answered on Sep 12, 2010
it is ok sir. but make sure to install necessary software drivers. most probably you need to download the NT Version of your drivers.
Toshiba Tecra... • Answered on Aug 17, 2009
HI,
Please see below for instructions on reset the BIOS password on your old Tecra.
  • Download KeyDisk from http://www.cgsecurity.org/keydisk.exe
  • Format a 1.44MB floppy disk and leave in your floppy drive
  • RunKeyDisk, this will create a special floppy disk to reset your laptop password.
  • Insert this disk into your Tecra laptop and reboot, the laptop should find the disk, boot from it and ask you for a password, press ENTER at this prompt and it will ask you for a new password.
If you have any further queries, please do not hesitate to ask
Regards
Bytestream
Toshiba Tecra... • Answered on Jul 25, 2009
Try taking the battery out and use only the AC. If everything turned out fine, it could be a problem on the battery or on the port.
Toshiba Tecra... • Answered on Jan 28, 2009
many toshiba laptops used a 15 volt supply, but look at he label attached to the bottom of the unit. it should spell out what voltage and what current (in amps). if a 15 volt supply is used that can only supply 100 milliamps, while the laptop needs more than 1000 milliamps, the laptop will play dead
Toshiba Tecra... • Answered on Sep 04, 2007
remove the hdd and attach to desktop . right click in my computer and run check disk in tools section in drive properties
Toshiba Tecra... • Answered on Sep 25, 2017
1. try with clear cmos and remove AC adapter and main battery. 2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
I have had this on an iphone 5. Apple sold me a new phone as it was not worth repairing and it was out of the 12 month warranty. Its possible to order a new part and do it yourself but unless you are totally confident and have the skills to open up your phone and reassemble it then its just not worth it.
Toshiba Tecra... • Answered on Apr 18, 2015
What is the actual question?
Toshiba Tecra... • Answered on Feb 02, 2015
look closely at the keys along the top of the keyboard (usually called F keys). one of them should have a tiny sun icon and the key beside it will have a larger sun icon. hold down the "Fn" key elsewhere on the keyboard while pressing the one of the sun icon keys to brighten or darken the picture. the sun icon keys may also be located on the Arrow keys (<-- --> etc.)
Toshiba Tecra... • Answered on Jan 31, 2015
Could be a very easy fix....does your computer seem a little to warm when this happens? If so the fix for this could be getting a better fan.
Sometimes when laptops run too hot they have a safety that shuts it off to prevent damage from heat.
You can find laptop fans pretty cheap on some computer part sites, also making sure your laptop is free from dirt and dust helps keep the temp down.
Toshiba Tecra... • Answered on Dec 31, 2014
When does it open on its own?Sometimes it is easy to be press the open button as you close it which of course opens it straight away.It can also fail to lock closed if not opened further than its initial amount that it does open.To close it after it opens you need to draw it back to rearm the mechanism.
Toshiba Tecra... • Answered on Sep 02, 2014
Toshiba Tecra 740CDT Notebook Logo
Popular Tags
8 questions posted
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Tecra Toshiba
  • Tecra Toshiba
Most Popular Question
power password
  • Computers & Internet
