20 Most Recent Bunn 340000068 6 Gal Model Black ULTRA2 AFI Frozen Drink Machine Questions & Answers
Lift it up from the hole at the bottom and off of the shaft
Bunn 340000068 6... | Answered on Jan 28, 2015
the sensor is inside the rear cowling and in the tube at the top behind the thermal wrap (black putty). pull it out and replace. you'll need to contact bunn for parts
lift it up from the post at the bottom and off of the shaft
there is a sensor on each side in the back that monitor the speed of the auger to determine thickness of the slush. if the sensor is dusty, it causes an error.
remove the 2 screws and the panel in the back behind the bowl on that side. you will see the motor and the sensor in front of it. use compressed air to blow out any dust. next, check to see if there are 2 pins on the shaft that pass the sensor. if one is gone, you will need to have it replaced.
Bunn 340000068 6... | Answered on Aug 03, 2011
Hi mikelupe64,
I saw your post you mentioned that the left barrel has a fault, and it Drops OFF voltage when the compress starts.
Part#'s
Assembly Manual
Possible that the Left condenser is experiencing problems causing the left barrel to drop voltage when compress starts.
Bunn 340000068 6... | Answered on Jul 06, 2011
It can be weak compressor or faulty auger motor or faulty valve connections.As you mentioned that valves loose voltage as compressor comes on, this is indication of weak compressor or main board.If the compressor voltage checks ok then its main control board problem.-------- You will have to test it with meter. ---------- This unit has a warranty on it, if its not very old.--------- The warranty details is as follows:-- 1) All equipment other than as specified below: 2 years parts and 1 year labor. 2) Electronic circuit and/or control boards: parts and labor for 3 years. 3) Compressors on refrigeration equipment: 5 years parts and 1 year labor. 4) Grinding burrs on coffee grinding equipment to grind coffee to meet original factory screen sieve analysis: parts and labor for 3 years or 30,000 pounds of coffee, whichever comes first ------------ This should help.Thanks.Helpmech.
https://www.fixya.com/support/t26902582-bunn_gourmet_ultra_2_message_bad_tic
and also to get a replacement TIC clock board
www.ebay.com > ... > Frozen Drink & Slush Machines
Rating: 5 - ‎2 reviews - ‎US$49.95 - ‎In stock
This circuit will work on any Ultra-2 including auto fill models. ... MARGARITA GUYS TIC BOARD REBUILD KIT "Bad TIC Clock" 32097.1001 PRIORITY p ... If you are a company with a large fleet of Bunn Ultra-2 machines, please contact us for ...
Bunn Kitchen... | Answered on Jul 15, 2020
already answered very comprehensively here on Fixya!
J Schneider
The Bunn Ultra-2 originally came with several circuit boards, including the main control board and a small memory board also known as the "TIC Clock". This little board, screwed in directly behind the main control board and has a small round metal circuit on it that looks like a watch battery, but it is not -- the metal "Can" contains the timing and memory functions for the main control board.
There is also a small battery inside the "can", which maintains the memory when power is removed from the machine. Over time, this battery will fail and you will see an error message on your LCD readout that says ":Bad TIC Clock". In the past you could just buy a new TIC Board from Bunn and install it and you'd be back on your way again. But, Bunn no longer sells the TIC Board and instead Bunn wants you to purchase a new Main Circuit Board that has the memory and timing functions built right on the new Main Board. The list price is over $200.
You can now purchase a TIC Board Rehabilitation kit from the Margarita Guys for under $50 which will replace the failed circuitry on the small TIC Board. Go to ebay and search "Bunn TIC Board" and you will see the kit available there. It includes all the necessary tools, 9 pages of detailed instructions and annotated photos, free Priority Shipping, and free phone access to their Bunn trained and certified Journeyman Technicians for any help you may need.
This should be the perfect answer to resolve your Bad TIC Clock message and the working errors that come with it.
Bunn Kitchen... | Answered on May 06, 2020
hi, from my experience 1. the main board/ecu may have a faulty solenoid. there are two solenoids on the board, 1 for each side. if the left auger works, then it's the right solenoid. its close to im[possible to replace the solenoids unless u have good connections to china!!
2. the right motor auger in the back might have a fault or bad electrical connection, very rare.
exchange the electrical connections to the motor from left to right and vice versa. then you know what is faulty.
3. good luck
4. you can order mainboards/ecu's at bunn.com. they r reasonable priced
Bunn Kitchen... | Answered on Dec 19, 2017
Bunn 340000068 6 Gal Model Black ULTRA2 AFI Frozen Drink Machine Logo
9 questions posted
Top Bunn Kitchen Appliances - Others Experts
Kelley Hopper
T. C. Hinson
T. C. Hinson
Level 1 Expert
Graham Leach
Level 1 Expert
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Bunn Kitchen Appliances - Others
Most Popular Question
remove support drum when shipped
  • Kitchen Appliances - Others
