Cq60 frozen mouse pad
Since you don't seem to want to help us in helping you, by being more detailed about your mouse, or mouse pad, problem, I will give you some general advice:- This is a laptop, yes?- It has one of those little areas where you can use your finger, instead of a mouse?- Look in Device Manager, or even in the Mouse option in Control Panel, and see if you have a mouse configured for your laptop, in addition to the built-in finger pad for use as a mouse.- If you find there are two separate devices, one for the laptop-supplied mouse square, or rectangle, with the buttons on the bottom, for use instead of a mouse, and one for an external mouse, then make sure you have designated the built-in pad for use as a mouse. If, however, you want to use an external mouse, then you do the opposite, and ensure that the external mouse is selected as the device you wish to use for a mouse, and disable the built-in mouse/finger pad software, so that you do not have a conflict.One or the other must be primary, and the one not primary must be disabled, or your laptop must be told not to use that other one. Apparently - again, because you gave us absolutely no details - there is a hardware conflict and the laptop doesn't know which device to use, so it is not using either, and you're stuck without the benefit of any pointing device.All the work you need to do with device manager and control panel must be done with keystrokes, and for that you must use Windows' Help to learn which keys will do what. Usually the four arrow keys, near the numeric pad, along with Page Up and Page Down, and the Tab button, or Shift+Tab, to go backwards, are all you might need to reset things the way they need to be set.I hope you understand that absent any details at all, the only advice you will get from anyone here, is going to be educated guesswork.Best of luck to you.Cheers!-a.
