20 Most Recent Toshiba Satellite LP154W01 Notebook Questions & Answers
LCD panel. i have several Toshiba laptop with bad LCD.
Toshiba... | Answered on Nov 04, 2009
It's not the inverter but the biotin backlight bulb that lights the display from underneath. The screen needs to be replaced unless you want to try and rebuild it and replace the backlight bulb. New screens from EBay should not be more than 70-100 bucks. If you want to try and replace the backlight bulb, the link is below for the procedure.....
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Toshiba... | Answered on Nov 03, 2009
If you can access the internet then go to www.toshiba.com and then download the update program again sounds like there is an address problem and this should clear it up
Toshiba... | Answered on Jul 28, 2009
Sounds like the Video setting is too high. Change the refresh rate lower and change the resolution lower. You monitor can't handle the setting that you have it on.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Toshiba... | Answered on Jun 09, 2008
Try to remove BATTERY and plug in AC POWER ADAPTER AND START IT.Let me know if it worked?
Toshiba... | Answered on Apr 11, 2008
First clean the fans out - these get clogged pretty easily.
If it gets stuck where you cant turn it off - hold down the power button for 5 seconds.
Hopefully the system hasnt been overheating for so long it has damaged the CPU or motherboard.
If the fans are clean and it still does it, you may have a bad stick of ram or the mainboard you bought may have problems.
I would inform the company you got the mainboard installed that it is having problems right away in case you dont have much time left in warranty.
Toshiba... | Answered on Dec 19, 2007
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
Toshiba... | Answered on Mar 19, 2020
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
Toshiba... | Answered on Mar 11, 2020
dvd players play vob or mp4 format. so try "convert x to dvd" software to burn your dvds in the right format http://www.vso-software.fr/products/convert_x_to_dvd/
Toshiba... | Answered on Feb 16, 2020
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
All drivers are available free of charge from Toshiba's web site.
Toshiba... | Answered on Jul 23, 2019
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
go to your browser proxy setting and make the proxy automatic
Toshiba... | Answered on May 21, 2019
Toshiba Satellite LP154W01 Notebook Logo
8 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba p10 laptop screen no longer
  • Computers & Internet
