20 Most Recent
Toshiba Satellite M55-S325 Notebook Questions & Answers
I have a Toshiba Satellite M55 that won't display
the serial / video cable is loose inside get it fixed properly if you are not a technician, otherwise you might loose the screen once it persists and it might short circuit the board !
9/30/2013 5:49:08 AM •
Toshiba...
Answered
on Sep 30, 2013
Wifi
you need to update your hardware drivers in device manager.
4/30/2013 5:50:55 AM •
Toshiba...
Answered
on Apr 30, 2013
Black screen
Press the ESC or F2 button on start-up and go into the BIOS and check the display settings
12/15/2011 5:44:19 PM •
Toshiba...
Answered
on Dec 15, 2011
Where can you purchase a
You may find the battery in places where they change batteries for watches.
The voltage is written on the battery.
8/23/2011 10:05:00 PM •
Toshiba...
Answered
on Aug 23, 2011
I need to install external
You can switch to anexternal monitor by two methods.
1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the external monitor.
2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key.
Toshiba = Fn + F5
8/10/2011 5:50:22 AM •
Toshiba...
Answered
on Aug 10, 2011
The Bios not see the
This indicates the hard disk is probably faulty or you are installing a hard disk that has a higher disk size capacity than the BIOS can support.
5/19/2011 11:22:50 AM •
Toshiba...
Answered
on May 19, 2011
The touchpad (and buttons) stopped working. No
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
6/25/2010 7:56:17 PM •
Toshiba...
Answered
on Jun 25, 2010
Is there sd card drivers available for my
If you are using WinXP or later, you shouldn't need sd card drivers. Try installing the latest software for your media reader from http://cdgenp01.csd.toshiba.com/content/support/downloads/sm50flashx.exe
5/15/2010 2:10:04 PM •
Toshiba...
Answered
on May 15, 2010
The touchpad stopped working after a powerpoint
FN + F9 should enable / disable the touchpad
goto control panel - mouse - and see if you can change disable/enable touch pad from there
Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads
Touchpad: - to enable or disable a touch pad/pointing device
from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon
Mouse Properties dialog box, click "Device Settings tab"
select the device
click to Enable or Disable
OR
You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10
see if touch pad needs to be enabled there
OR
one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
4/12/2010 8:59:17 AM •
Toshiba...
Answered
on Apr 12, 2010
When
you need to boot with CD first, go to BIOS using DEL key and set first booting drive to CD drive and then you will get the option for repair
2/10/2010 10:29:44 PM •
Toshiba...
Answered
on Feb 10, 2010
Toshiba Satellite M55-S325 PC Notebook outsde case
You definitely need to bring your laptop to the Toshiba shop near you. There they can facilitate the replacement of your laptop's body (casing). It is a critical task to do and I think a Toshiba authorized shop can help you with this. Thanks.
2/3/2010 2:46:22 AM •
Toshiba...
Answered
on Feb 03, 2010
