20 Most Recent Hitachi WH18DLP4 18Volt Lithium Ion Cordless Impact Driver No battery or charger Questions & Answers
3answers
Problem with hitachi chargers
I live by hitachi, one of the good things about it is lowes will exchange them as long as you have a receipt and it's under 30 days. If not chargers are not very expensive, or you can send it back for repairs. I have 10 of those combo packs and never had a problem with a single one, for you to get 2 is a freak accident.
5/12/2016 8:32:56 PM • Hitachi WH18DLP4... • Answered on May 12, 2016
NEED BATTERY CHARGER 732751OR732745
New chargers for the WH18DL4 are available item is UC18YRL
1/2/2013 1:21:36 PM • Hitachi WH18DLP4... • Answered on Jan 02, 2013
I have a ds18dfl hitachi drill and i want to up grade to a better chuck . do you have any advice for a upgrade?
The OEM chuck for that is about 45 dollars. There are no substitutes offered.
5/9/2020 11:39:54 PM • Hitachi Drills • Answered on May 09, 2020
Hitachi tool charger UC 18ygsl, no light, will not charge battery. Was working fine until I went to charge a battery..then light went out
If its not an bad soldering or an passive component , beware almost all brands wenn ordering an electric part for a charger its almost always more expensive then a complete (new charger ) the latest years there are more and more remplacement options to the customer , if there are defect components that are not made for ordering on marketing technical reasons and safety and more reasons. mosnfets (passive component almost sometimes fuse resistors but smd components to repair is not meaningfull . when termical defects are hidden.
1/18/2019 3:01:48 AM • Hitachi Drills • Answered on Jan 18, 2019
Are the brushes in a Hitachi DV18DCL2 impact drill driver, replaceable
Generally the answer is yes for most models. Check the manual.
4/13/2018 3:59:03 PM • Hitachi Drills • Answered on Apr 13, 2018
Hitachi cordless DS 18DGL is stuck closed and cannot release
Leave the part that is stuck in a jar with petrol overnight and then put it in a vice and try then to open then with spanner at the end of the chuck hope this helps
2/18/2018 5:33:46 PM • Hitachi Drills • Answered on Feb 18, 2018
How to remove a drill chuck from an Hitachi corded drill
How to Remove Drill Chuck If there is screw in inside center of chuck remove it, it is probably left hand threads so pretend you are tightening it and it will come free. open chuck fully and insert chuck key into holes and hit it with a hammer to remove it.
10/12/2017 6:46:05 PM • Hitachi Drills • Answered on Oct 12, 2017
Where is the serial number on a hitachi DV18DGL combi drill
Replacement HITACHI DV 18DGL battery pack 100% compatible with the original DV 18DGL battery, high quality, wholesale price. http://www.drillbattery.com.au/buybattery.php/hitachi_DV+18DGL_power+tool+battery.html
7/21/2017 1:49:03 PM • Hitachi Drills • Answered on Jul 21, 2017
Any one know where a chuck for Hitachi Power Tools Ds14dvf3 can be purchased, it is a discontinued item, and no parts seem to be around? OR is there a universal chuck that could be used in this drill?
I'm hoping you mean a chuck "key" .... there are only 4 different sizes and can be bought in tool stores as universal chuck keys tool 4 in 1 tool...
5/15/2017 4:29:25 PM • Hitachi Drills • Answered on May 15, 2017
Hitachi drill jaws do not move, can not hold bit
You need to replace the drill chuck.
5/12/2017 9:13:40 PM • Hitachi Drills • Answered on May 12, 2017
Hitachi 24v sds hammer drill issues with speed when pulling back trigger switch sometimes works other times nothing, already changed dc speed control trigger any ideas to what the problem is? Thanks
faltering on a slide contact on electric field or switch, but in most cases dirth (dust) in carbonbrushes can be hanging somewhat in one or both brushholders. Or a problem in the trigger switch itself dust and dirth have almost the highest priority in case of faltering by clamping carbon brushes.
10/23/2016 9:14:07 AM • Hitachi Drills • Answered on Oct 23, 2016
Hitachi WH18DLP4 18Volt Lithium Ion Cordless Impact Driver No battery or charger Logo
2 questions posted
Top Hitachi Drills Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
View Most Popular
Hitachi Drills
  • Hitachi Drills
Most Popular Question
problem hitachi chargers
  • Drills
