20 Most Recent
Philips SHM1900 Headset Questions & Answers
Microphone
You need to supply a few more details to work out what you are asking here!
Philips shm1900 headset on Lenovo thinkpad t430 with windows 7
It sounds like you are still using the mic on the laptop. Because you are far away from it, it sounds like echo.
Make sure the phillips headset is selected in the Windows mixer.
Make sure you are plugged into the mic jack on the laptop.
Make sure the mic is not muted. This is a default setting.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
