20 Most Recent
Harbinger APS 15 Powered PA Speaker Questions & Answers
Harbinger ha120 no sound to speakers. What's wrong?
It could be a number of things. Does the head light up when turned on? Are the controls on the channel turned up? Is the master turned up? Have you checked continuity on the cables? Have you tried the speakers with another amp, or the amp with other speakers? This will help narrow down the problem.
Speaker shorted out
If you do not have training in electronics you can cause serious damage to yourself trying to fix this. You will need to take this into the shop.
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
