20 Most Recent
Kodak Advantix T550 Auto Focus APS Point and Shoot Camera Questions & Answers
Problems with camera display on kodak APS (something or other......)
I am having exactly the same problem (I have a T550). On the last film I shot, the only way to advance the film was to pull the battery out and re-insert it every time. When I printed that film, all the frames are blank!
Kodak's FAQ about "clearing the logic" suggests a solution for that problem.
1. Turn camera off
2. Pull battery out
3. Turn camera on
4. Click the shutter approximately 6 times
5. Turn camer off
6. Repeat step 4
7. Reinstall battery
I just tried that but the problem persists. I am now going to leave the battery out for several hours; maybe this will help. Otherwise, well it is time to bite the bullet and buy a digital !
How do i put a film on a kodak star 435 35mm? the tab to roll the film doesnt seem to work. I dont know if I am doing it wrong or if my camera is broken.
To the best of my knowledge all 35mm cameras load identically, apart from a few automatic models that claimed to be self loading.
A new film cassette has a tongue of film protruding. Once the cassette has been loaded into the recess on the left and the rewind crank pushed down and engaged with the film spool, a couple of inches of film is pulled from the cassette and the tongue poked through the slot in the takeup spool - it might be necessary to use the film advance until the slot is visible.
With about a half-inch of film pushed through the slot, slowly advance the film until the slackness is gone while fully engaging the sprocket holes at the edges of the film on the teeth of the sprockets. Advance the film a little more to check it is properly engaged and once you are satisfied close the camera back firmly making certain the catch is engaged and it won't spring open again.
Once closed, advance the film until it stops which signals the shutter is set and is ready to take a photograph, however the first and perhaps the second frame has been contaminated with light and so press the shutter release, advance and press again and the third advance is where the photographs begin. If there is a frame counter it is best to be guided by this.
Cameras that have a manual advance usually have a manual return crank that will be seen to rotate as the film is advanced. When all the frames have been used the film will be felt to come to the end. At this point the clutch button must be pressed to disengage the wind-on mechanism and the film wound back into the cassette using the crank on the left.
9/30/2020 7:13:36 AM •
Kodak...
Answered
on Sep 30, 2020
I have a Kodak Vigilant Six-16 camera. It also
It's collectable, but really isn't worth much at all even in absolutely perfect and fully functional condition. Plenty were made, they're not that special, they certainly aren't usable any more and so they have very limited appeal.
The few really good ones I've seen over the last ten years or so have typically sold for around £40-£50 maximum, and often haven't sold on the first attempt. In any other condition they're either worthless or go for up to £20-£30 depending upon how much interest there is on the day. Basically they are simply worth what any buyer is prepared to pay when you happen to sell them. Id sold at auction, collectors rarely compete as they know another one will be along shortly.
My prices are UK indicators, you can expect prices in N.America to be around 30% lower and in mainland Europe to be around 10-15% lower.
9/21/2011 9:21:48 PM •
Kodak...
Answered
on Sep 21, 2011
