20 Most Recent Kodak Advantix C470 APS Point and Shoot Camera Questions & Answers
To the best of my knowledge all 35mm cameras load identically, apart from a few automatic models that claimed to be self loading.
A new film cassette has a tongue of film protruding. Once the cassette has been loaded into the recess on the left and the rewind crank pushed down and engaged with the film spool, a couple of inches of film is pulled from the cassette and the tongue poked through the slot in the takeup spool - it might be necessary to use the film advance until the slot is visible.
With about a half-inch of film pushed through the slot, slowly advance the film until the slackness is gone while fully engaging the sprocket holes at the edges of the film on the teeth of the sprockets. Advance the film a little more to check it is properly engaged and once you are satisfied close the camera back firmly making certain the catch is engaged and it won't spring open again.
Once closed, advance the film until it stops which signals the shutter is set and is ready to take a photograph, however the first and perhaps the second frame has been contaminated with light and so press the shutter release, advance and press again and the third advance is where the photographs begin. If there is a frame counter it is best to be guided by this.
Cameras that have a manual advance usually have a manual return crank that will be seen to rotate as the film is advanced. When all the frames have been used the film will be felt to come to the end. At this point the clutch button must be pressed to disengage the wind-on mechanism and the film wound back into the cassette using the crank on the left.
Kodak... | Answered on Sep 30, 2020
Again, most kind of you to pass on this information. Was there any particular reason behind your doing so ?
Kodak... | Answered on Aug 24, 2017
If you are disabled, and use a walking frame, you should be able to get assistance from the Social Services department of your local council
Kodak... | Answered on Aug 17, 2017
Sorry these types of items are not serviced. My suggestion is to make one.
Kodak... | Answered on Jan 11, 2017
Kodak Advantix C470 APS Point and Shoot Camera Logo
0 questions posted
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
View Most Popular
Kodak Photography
  • Kodak Photography
Most Popular Question
put film kodak star 435 35mm tab roll
  • Photography
