20 Most Recent Kodak EasyShare LS753 Digital Camera Questions & Answers
[PDF]Kodak EasyShare LS753 zoom digital camera
resources.kodak.com/support/pdf/en/manuals/.../LS753_GLB_en.pdf Kodak EasyShare. LS753 zoom digital camera. User's guide www.kodak.com. For interactive tutorials, www.kodak.com/go/howto. For help with your camera, ...
Kodak EasyShare... • Answered on Sep 08, 2015
They may be locked, go into the options menu and unlock the photos.
Kodak EasyShare... • Answered on Apr 16, 2014
how to delect pictures on slice
Kodak EasyShare... • Answered on Apr 13, 2014
You can recover photos from camera with asoftech photo recovery program. You can download the program fromhttp://www.asoftech.com/apr/You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Kodak EasyShare... • Answered on Nov 26, 2013
SD cards max out at 2GB. Larger cards are actually SDHC cards, which will not work in devices not designed to use them.
Kodak EasyShare... • Answered on Dec 01, 2012
The LS743 works with MMC and SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards. You need to use cards 2GB and smaller.
Kodak EasyShare... • Answered on Nov 27, 2012
Error # 45 means the retractable lens is stuck, possibly caused by a drop or sand or other gunk that has jammed the gears. It will cost more to have repaired than the camera is worth, so you have nothing to loose by trying this. Hold the camera in your strong hand with the lens away from you and smack it hard into the palm of your other hand (if you can't take pain maybe use the heel of a shoe) pretty hard. It may take several tries. Best results - smack camera immediatly after turning off.
Kodak EasyShare... • Answered on Dec 13, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Kodak EasyShare... • Answered on Nov 06, 2011
Hello
Regards
Andrea
Kodak EasyShare... • Answered on Sep 08, 2011
Hello
Regards
Andrea
Kodak EasyShare... • Answered on Jul 14, 2011
Hello and Welcome to FixYa!
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this follow the given solution:
You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact Kodak to see if your camera is still under warranty, otherwise contact any Kodak Cameras service provider, your problem will be solved.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Kodak EasyShare... • Answered on May 09, 2011
Try tapping the side of lens, or smacking the camera gently on the palm of your hand when it's on, then restart the camera. It could be a problem with the lens mechanism, and the gentle, yet firm tapping may help.
Kodak EasyShare... • Answered on Mar 01, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Kodak EasyShare... • Answered on Jan 22, 2011
Hello
Regards
Andrea
Kodak EasyShare... • Answered on Jan 19, 2011
Hello
Regards
Andrea
Hello
Regards
Andrea
Kodak EasyShare... • Answered on Jan 16, 2011
Kodak EasyShare LS753 Digital Camera Logo
53 questions posted
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
kodak easyshare ls753 lost pictures
  • Cameras
