20 Most Recent
Harman Kardon HK 3490 Questions & Answers
VOLTAGE PROTECTION CHECK DSP
AMPLIFIER HARMAN KARDON:
Code: <check input> means: fuses resistors back of the transformer. They should have .4 ohm low ohm. Often they go on kilo ohms or mega ohms, means they are open. Change them. That's it. Code: <Check DSP> means something on logical board or flat strap connectors defect. Also check voltage on output collector and also check -15 volts and +15 volts on multiplug up on the middle right of the amp on the logical board. Check all voltage preamp on connector cn21 and cn24 on right of the logical board up middle right of the amplifier. I'm a certified Harman kardon technician. If you have other questions, just ask me. Good luck all. Serge.
Why Harman Kardo HK 3490 goes into DSP voltage protect mode
This amplifier can go into protection if one of the low ohm resistors on the power module that is soldered to the transformer is defect. Check out R951 and R952, they are both 0R47 (0,47ohm). They are often broken and measure some kilo ohms.
Harman Kardon AVR 630 8CH mode not available
According to the Harman-Kardon AVR 630 User Manual, if the 8CH mode is not available, you can try unplugging the unit from the AC wall outlet and waiting for at least three minutes. After the pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system reset may clear the problem. The 8CH may not be available according to the user manual. You need to contact Harman-Kardon customer support.
