20 Most Recent
Fujitsu LifeBook S751 l Core i5 2520M Questions & Answers
Install new keyboard
The majority of laptop keyboards are attached in a similar fashion. Replacement typically involves removing a bezel gently so as not to break it, depressing three small tabs that hold the keyboard in place and then disconnecting the ribbon cable underneath the keyboard.This general Fujitsu laptop guide may be helpful:http://www.ehow.com/how_5941166_open-fujitsu-laptop.html
Need help
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
How can i reset bios code ?
remove the bios password by removing the
cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the
case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Keyboard
Sounds like liquid may have been spilled on the keyboard.
Plug in an external usb keyboard and check if it works.
If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
