20 Most Recent Toshiba 40E210U 40 in. LCD TV Questions & Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Toshiba 40E210U... | Answered on Nov 17, 2015
Sounds like main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Toshiba 40E210U... | Answered on Apr 23, 2014
Video display card could be bad but I wouldn't rule out the power supply just yet. It breaks off in several directions and the lead going to the display driver could be bad. Put a meter on it to see.
Toshiba 40E210U... | Answered on Nov 01, 2013
I was having this exact problem. You have to go to the "Audio MIDI setup" icon in the utilities folder. plugin your mac to the HDMI and TV and it should show up on the menu bar on the left as "HDMI"- then click it. then you have to click on the "format" drop down menu and change it to either 48000.0Hz or less. Make sure that the volume is down on your TV bc I almost gave myself a heart attack when I clicked it. Apparently the TV HDMI input is not compatible with the default on the Mac. Hope this helps!
Toshiba 40E210U... | Answered on Apr 08, 2013
Unfortunately, not all Toshiba TVs have a headphone jack, The 40E210U is one of those models. The above referenced model only has digital audio out. You would need a digital to analog audio converter and then RCA stereo to 3.5mm adapter to plug in most headphones.
You can always look on the back and side of your TV and look for a 3.5 mm port with a headphone symbol. If you have a different model, many Toshiba product manuals are available here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp . Click on Product Support and then use the drop-down menus to select your product. Then click on the GO! button and choose the User's Guide tab.
I wish that I had better news for you.
Toshiba 40E210U... | Answered on Dec 07, 2012
Disconet from the wall Overnight.
Toshiba 40E210U... | Answered on Nov 04, 2012
If you keep getting this problem(green light turn on for 5 to 10 seconds then TV shuts down along) you get to try this:
On ebay seach, type in "40E210U dead" there is one solution, good luck!
Toshiba 40E210U... | Answered on Nov 03, 2012
It will have to be taken into a repair shop.
Toshiba 40E210U... | Answered on Oct 21, 2012
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Toshiba 40E210U... | Answered on Aug 03, 2012
The SMPS or inverter is switching on and off, possibly due to leaky/dry capacitors or dry solder. This is a case to be looked into by a qualifies service technician.
Toshiba 40E210U... | Answered on Jul 29, 2012
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_3_2012_1_48_15_pm.jpg6_3_2012_1_48_47_pm.jpg
Toshiba 40E210U... | Answered on Jun 03, 2012
Toshiba 40E210U 40 in. LCD TV Logo
54 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
find headphone jack toshiba lcd
  • Televison & Video
