20 Most Recent Mitsuba DV777 Camcorder Questions & Answers
Are the batteries fully charged ?
Mitsuba DV777... | Answered on Jun 17, 2017
The camera doesn't need a driver to transfer the pictures/movies to your computer. Windows should open a dialog box asking what you want to do. The only "driver" I found was from http://mitsubausa.com/support.htm
Both the DV500 and DV505 drivers listed under 'After01May 2008 are the same and look like the camera they are for is the same spec as the DV777
Mitsuba DV777... | Answered on Oct 31, 2012
You can find a manual at http://mitsubausa.com/Download/manual/DV7/MANUAL_EN.pdf
This "manual" is identical to the one included with the camera.
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
If the green light on the charger is lit when the charger is plugged in, then the connection between the charger and the power supply is good. this is a fragile connection from what I have seen. check the wires right at the connector. The connector does not have any strain relief for the cable.
I suspect, however, that the problem is not the power supply/cable, but the charger itself. If you look closely at the 2 terminals that connect to the battery, you can see that they are just 2 tiny wires that can bend very easily if you are not extremely careful when putting the battery in. The terminals are supposed to spring towards the LED, not down. If you put the battery in by pushing down, instead of towards the LED, you will probably bend the terminals, preventing electrical contact. You can fix the bent terminals or get a replacement charger. replacement chargers are not cheap, but at least they work on a lot of different batteries, have a USB charging port and can charge 2 AA batteries. Lenmar BCUNI2 and Lenmar BCUNI3 are 2 suitable replacements.
I'm sure you do. Fixya, however, does not offer repairs - all I can suggest is that you contact your local electronic repair facility, or else the manufacturer.
Mitsuba Video... | Answered on Apr 14, 2019
I would suggest that to get a diagnosis of the fault that you take it to a reputable camera shop and get some idea of the problem
preferable a shop that sells that make of camera
Mitsuba Video... | Answered on Nov 08, 2015
type in the make and model along with the word driver into google and this should provide you with a phew options to download your driver. hope this helps.
Mitsuba Video... | Answered on Mar 27, 2013
I have it. I would need to copy it and mail it.
Contact me at [email protected]
Mitsuba Video... | Answered on Jan 12, 2011
According to the manual you can.
You move the joystick to the left to enable the flash!.... took me forever to figure it out lol.... hahaha
Mitsuba Video... | Answered on Oct 14, 2010
I have it, but I need to copy it and mail it.
Mitsuba Video... | Answered on Mar 18, 2010
Mitsuba DV777 Camcorder Logo
Popular Tags
15 questions posted
Top Mitsuba Video Cameras Experts
Ekse
ChinthakaJ
ChinthakaJ
Matt Palmer
Level 1 Expert
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsuba Video Cameras
Most Popular Question
camcorder wont turn all
  • Video Cameras
