20 Most Recent
Minn Kota Maxxum 70 Universal Motor/Sonar Combo Questions & Answers
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Prop turns with fwd selected
Check the shaft to the prop. Make sure there is not buildup or anything caught inside slowing the movement. Check the motor crank and shaft, make sure nothing is rubbing or haning up.
Minn Kota Maxxum Trolling Motor
I had the same problems with my 70lb, my motor just quit while on the lake, took it to a minn kota service repair shop. I had two issues. One was the little magnet under the button on the foot pedal got recessed to far down, the tech told me if it happened again pop the button off and pull the magnet up some. Simple fix. I took it home put it back on the boat and nothing just a slight ticking noise heard from the pedal with no prop movement. So I thought maybe somethin was wrong with one of my batteries. Unhooked everything, tested both of them, all good. Even though there was hardly any corrosion, I clean everything, hooked it up and "WALLA"! Power! Problem solved, for now. Waitng to test again out on the lake
Minn Kota tolling motor
Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
MINN kOTA 70 LB THRUST FOOT CONTROLLED TROLLING MOTOR
VONNY MY MOTOR DOES THE SAME THING AND I FOUND THAT THE DUST OF THE MAGNETS IN THE HEAD WAS CAUSING THE MOTOR TO STICK I CLEANED INSIDE WITH ELECTRICAL CLEANER AND IT STARTED TO WORK FINE BUT YOU MAY HAVE SOMETHING ELSE GOING ON AND ALSO MAY SURE YOU ARE NOT COVERED UNDER WARRANTY IF YOU JUST GOT THE BOAT
What do you think about new york city exterminators?
There are various websites on internet that are presenting new york city exterminators. These are specially-made for those people that are trying to find quality service. To find out more please visit with this site :http://www.mypestsolutions.com/
4/18/2024 4:19:04 AM •
GPS
Answered
on Apr 18, 2024
