20 Most Recent Singer 7258 Sewing Machine Questions & Answers
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john-michael_38e8d20d2052609c
Singer 7258... | Answered on Mar 06, 2020
I had this problem too. What I did was turn the post the bobbin sits on to the left (lefty-loosy) and kept re-booting the sewing machine until the bobbin started to spin correctly and the needle disengaged! I was so happy I figured it out, I did not want to return the sewing machine.
Singer 7258... | Answered on Aug 02, 2019
the machine comes in two versions european {220-240v}
or american {110v}
you need to use a transformer to give 110-240v
the current this machine uses is less than 3amps
so a 3amp 110-240v converter is easily found on ebay for $10
Singer 7258... | Answered on Jan 06, 2019
Talk to your local target store and see if they'll accept it as is; otherwise get hold of Singer (http://www.singerco.com). Generally, electronics die in the first 90 days if they're defective...
If you bought it with a credit card, talk to the credit card folks, too.
Singer 7258... | Answered on Oct 18, 2018
if the sewing machine is set on the buttonhole setting then it's
possible that the sewing machine motherboard has a problem.
or a part could be damaged, the machine may need some type
of adjustment.
Singer 7258... | Answered on Sep 15, 2018
http://www.fixya.com/support/t18116338-reset_e7_error_message
Singer 7258... | Answered on Feb 24, 2017
Well, you COULD get this fixed -- or you could purchase an inexpensive bobbin winder and skip the whole issue. Does a better job, too.
Singer 7258... | Answered on Dec 28, 2016
could be damaged or broken, may need to be replaced
Singer 7258... | Answered on Feb 17, 2016
Bobbin problem on Singer - YouTube
? 6:44
www.youtube.com/watch?v=0MxKDTeH2p8
Sep 29, 2010 - Uploaded by CandiceMi5 This is a new machine and I threaded it and filled the bobbin right.... How to Fix / Repair the Hook Timing on a Sewing Machine - Duration: ...
how do i fix error code c4 on a singer sewing machine? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jun 25, 2013 - Best Answer: The answer should be in the back of your instruction manual in the troubleshooting guide. Error codes can vary from machine to ... singer 6160 sewing machine giving error code c4?
Oct 1, 2014
Singer sewing machine problems?
Feb 20, 2014
Going to kill my sewing machine! Why the constant C4 error on ...
Jul 13, 2012
Singer Brilliance 6180 C3 Error? (Sewing Machine)?
Mar 10, 2012
More results from answers.yahoo.com
Singer 7258... | Answered on Oct 01, 2015
Hello Thelma!
No need to pay, we are here to help the Fixya community with our experience, kindness and knowledge. Here two links to your manual.
Click, Download to your PC & Enjoy!
JP
SINGER 7258 Instruction Manual
Singer Stylist 7258 Features And Benefits
Singer 7258... | Answered on Jun 30, 2015
Unfortunately, your machine's manual doesn't list the meaning of error codes. You have two choices. Either go to the Singer site and send an email to customer service, or call their customer service department--if you do that, call as early as possible--8 am is a good time.
You could also purchase the service manual; I took a look at ebay, and there is one for sale there on CD for $14.95. You can also contact Sewing Parts Online; they carry service manual, although when I checked, they don't have yours in stock. However, you can send them an email or call them (recommend calling), and they are most accommodating about ordering service manuals and parts that they don't have in stock.
Singer 7258... | Answered on May 25, 2015
Many things can cause a machine to be hard to turn. Lint and tread are the first suspects. Thread can be caught in the shafts or gears and this will cause a bind. I have found entire spools of thread under the hand wheel. This was not even the thread she was sewing with at the time. Watch this video of how it happened.
https://www.youtube.com/watch?v=-SIg_3-AMJo
Singer 7258... | Answered on May 09, 2015
The loud sound suggests that the moving needle and the moving parts of the bobbin system are no longer timed properly>
If this is the case you cannot fix it yourself and I can"t tell you how to do it
A qualified technician can do it>
Sorry I cannot be more help but my layman knowledge does not cover that!!!!!!
Singer 7258... | Answered on Apr 22, 2015
Could you please clarify this issue? Is your power cord missing, or you have it and the machine doesn't turn on?
I just took a look at the user's manual for your machine, and your power cord is a standard two-prong polarized laptop cord--you can buy it at any computer store. You may have similar cords around the house on, for instance, your printers. Your first step is trying another cord--that's generally the problem.
If it still doesn't go on, I'm afraid that you'll have to have a technician take a look at it--it could be anything from a blown fuse, to a defective motherboard, to a bad motor.
Singer 7258... | Answered on Feb 23, 2015
Without being able to personally troubleshoot, analyze, and diagnose the screeching, no one is going to be able to solve the problem.
That said, for your understsnding of the gravity of the situation, I provide the following info and warnings!!!!!
Loud screeching like you describe is INDICATIVE OF either a pulley-belt joint slipping at very high speed, OR a BEARING in a high speed application binding, NEITHER OF WHICH IS GOOD!!!!!
To prevent possible total destruction of your machine, I strongly suggest the you unplug it UNTIL you can get it to a QUALIFIED repair TECHNICIAN for troubleshooting.
The symptoms you describe are indicative of a very serious problem which could result in severe damage to your machine!
Singer 7258... | Answered on Jan 17, 2015
I just checked your user's manual, and unfortunately it only lists error codes up to E5. There are several things I would check, though. You're saying that it stops working; I would remove the cover over the thread path--it's separate from the front and back, and may be removed by the user for cleaning--and check to see if there are any threads wrapped around something, preventing the machine from working. I would also check that the bobbin winder and buttonhole lever are in their correct positions. When it stops, try to sew manually by bringing the hand wheel towards you (ALWAYS towards you--never away from you.)
Once you have ruled out user error, you might want to send an email to Singer customer service, asking what the code means, because while it might not be in your user's manual, it is probably in the service manual.
If those haven't worked, it's time to buy the service manual. I get mine from Sewing Parts Online; I checked, and it's not listed as in stock, but if you will call or email them (calling is recommended), they can and will order it for you, and their charges are reasonable.
Singer 7258... | Answered on Nov 29, 2014
Try a new needle
Singer 7258... | Answered on Nov 26, 2014
Singer 7258 Sewing Machine Logo
85 questions posted
Top Singer Sewing Machines Experts
Irene Tulloch
Chris Wetmore
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
need manual singer 7258 dont printer
  • Sewing Machines
