20 Most Recent Minn Kota 55 AutoPilot Universal Sonar Combo GPS Receiver Questions & Answers
0answers
I have ap55 motor will
Hi, I think I know what has happened to you.
You asked if cold weather will affect the steering pedal, and the answer is yes.
What has most likely happened, is that your control pedal has gotten wet, then froze somehow, might have been snow, could have been ice, it could have even been just plain old fashioned condensation.
When it gets cold the moisture will condense, and attach to almost any surface, and has likely caused a slight corrosion problem.
I would take the bottom off of the pedal, and try to clean the contact points inside the pedal, as this is the most likely cause. Now if there is a separate switch for directions, I would look at cleaning the contacts inside it as well.
Also, wires can corrode with moisture, so look to make sure that where the wires hook up there is a good clean mating surface, that way the wire gets a good connection.
Now, what might have happened as well, is that when you stowed the boat, somehow the wires the the steering controls got damaged somehow.
You may have to use a circuit tester and check each wire for continuity, that way you know if there are broken wires inside the wire casing.
Ihope this provides some guidance for you today, and happy boating !
1/29/2011 3:29:36 PM • Minn Kota 55... • Answered on Jan 29, 2011
I have a min kota trolling motor ser. #2050
Click on to.." Northland Marine.Com ..they can help with you're inquiry.
10/3/2010 8:22:43 PM • Minn Kota 55... • Answered on Oct 03, 2010
2answers
The motor keeps blowing the in line fuse whenever
Ok, Now motor use "Special" fuses, it is like a Slow Blow, as when a Motor starts up it can and does draw many many times it's rated Current... I suspect you are NOT using the correct fuses/breaker, you sold try simply upping the Fuse rating, a bit, as long as you are sure that all is well. However you may find you actually have a fault?. Motor speed controllers, can work fine "Down Low" but when it is turned up to maximum it may draw so much current that the Fuse or breaker is tripped, or blown... have you checked out your motor rating versus fuse breaker rating, you need a bit of "Headroom" as stated with a motor. it draw as a lot of current and the system has to be flexible enough to accommodate this.
7/22/2010 9:22:58 PM • Minn Kota 55... • Answered on Jul 22, 2010
Hi, My MinnKota Auto Pilot will
When the foot pedal was tucked away under the boat and not connected you will face this problem .
Hope this helps .
3/20/2010 6:27:43 AM • Minn Kota 55... • Answered on Mar 20, 2010
I have a 24v pd2 70ib thrust trolling motor. What
Hello there:
the 24v tells you that you need 24 volts ok so what you will need to do is to get 2 12 volt batteries and put them in series than run this to the motor this is usually done with a disconnect switch in the line with your start switch ok? you can also contact the manufacture of the motor for further details
Hope this is very helpful
Best regards Michael
2/1/2010 3:53:01 AM • Minn Kota 55... • Answered on Feb 01, 2010
I have a 1999-model Minn-Kota bow-mount trolling
55 is a 12 volt system northland marine has diagram.
1/29/2010 12:31:57 AM • Minn Kota 55... • Answered on Jan 29, 2010
Minn Kota 24v auto pilot. will track correctly
Usually this means that there is a crack in the coil cord or there is something metal close to the head of the motor.
The coil cord can be checked while you are out fishing next time by grabbing the cord (black coiled cord from base to head of the motor) and stretching it and pulling on it. If the motor reacts to the pulling then that's the problem.
best of luck!
Mike
9/26/2009 10:08:38 PM • Minn Kota 55... • Answered on Sep 26, 2009
My motor just quit working all of a sudden. I
call minkota support!!!
6/28/2009 8:36:52 PM • Minn Kota 55... • Answered on Jun 28, 2009
2answers
Won't stay on track
You need a new foot petal
4/27/2009 6:51:26 PM • Minn Kota 55... • Answered on Apr 27, 2009
Minn Kota lower unit leaking.
Man, you have a job ahead of you. First, if the unbreakable shaft is cracked or broken, you will have to replace it, for it will leak into the motor too. If your unit has the sonar sensor in the front and it has had water in it, the unit can corrode severely and need a lot of parts besides seals. The wiring to the sonar runs in a protective shield bonded to the magnet housing and one of the long screws holds it in there. Remember to take the wiring to the sonar out AFTER you remove the big motor feed wires, and replace it BEFORE you reinstall the red and black cables. Some grease seems to ensure the o'rings slide on metal parts during reassembly rather than tear. It's quite a job.
11/28/2008 11:00:18 AM • Minn Kota 55... • Answered on Nov 28, 2008
Broken composit carbon shaft on
Lifetime gaurentee on the shaft, a dealer should be able to help you out
10/25/2008 12:48:03 AM • Minn Kota 55... • Answered on Oct 25, 2008
2answers
The Minn Kota trolling motor
I have the same problem with a 765mx 36 thrust. I am going to check the power going to the motor with a meter. I think it may be the PC board has gone bad. I will write back with my findings
10/2/2008 11:07:16 PM • Minn Kota 55... • Answered on Oct 02, 2008
Shaft
It is not recommended to cut the transducer cables as they are sensitive to outside interference.  Most trolling motors have adjustable shafts so you can set it at the depth you want. Look for a locking mechanism where the shaft attaches to the mounting bracket.
12/4/2007 6:38:12 PM • Minn Kota 55... • Answered on Dec 04, 2007
0answers
2answers
Minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
6/20/2013 12:40:26 AM • Minn Kota GPS • Answered on Jun 20, 2013
0answers
0answers
GPS Logo
23 questions posted
Top Minn Kota GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
View Most Popular
Minn Kota GPS
  • Minn Kota GPS
Most Popular Question
  • GPS
