20 Most Recent
Toshiba e830 Pocket PC Questions & Answers
Bitmap caching
To disable imageon device bitmap:
create following registry entry:
HKEY_LOCAL_MACHINE\System\GDI\Drivers\ATI\ DisableDeviceBitmap
and make it equal to 1
Toshiba e830...
Answered
on Sep 08, 2005
About installed software..
I think that “Microsoft pocket pc 1996 - 2003 os” called now “Windows Mobile 2003”.
To upgrade your PDA to 2003SE please go to TOSHIBA Site
http://www.toshiba-europe.com/. Than go to Computer systems.
Under “Support &Downloads” there is option Download Drivers. Please chose your PDA and there are all useful Drivers for “Windows Mobile 2003 SE”. In every zip File there is “Upgrade Guide”. Read it. It can help you to make update without problems.
Toshiba e830...
Answered
on Sep 08, 2005
WM 2003 SE update error ???
I had the same problem with mine e800. But after many of attempts I was able to make an update. Problem was connection between notebook and PDA. Check connection settings and try it again. It must work.
Toshiba e830...
Answered
on Sep 08, 2005
E830 hangs on soft reset
Believe me it is not easy to say what the problem can be. Your problem is very specific and I don`t believe that someone can give you some help because this “software” that you have implemented is unknown to other users.
I suppose that there must be some bug in software and after installation there is some memory error. I also know that e830 needs about 3 or 4 minutes for reboot.
Toshiba e830...
Answered
on Sep 08, 2005
Internet connection at my e830
To configure the Wireless connection you can use the Wifi connection wizard or setup the connection manually. I hope that you have checked your workgroup too.
Also you should check if your IP settings are the same at the router and PDA (dynamic and static IP)!
If you have some another device connected to the router remember them when you setup the PDA connection!
In the end the MAC address of the PDA WLAN card must be saved in the router!
Toshiba e830...
Answered
on Sep 08, 2005
Setup.exe doesn't run
In my opinion you should check the user`s manuals because there is described the whole procedure. You can also check the Toshiba download site. There you can find all documents, even the Upgrade guide if you want to upgrade the PDA.
Toshiba e830...
Answered
on Sep 08, 2005
TomTom 5 BT mouse: no Connection
A friend of mine uses the same software for his PDA. I have asked him what the problem can be and he told me that some kind of “connection registry” or something like that is very important.
Start PDA and start the Bluetooth. Go to Bluetooth symbol and choose BT settings. There must be shown some “magnifying glass”. Click on it and the search will start. All visible objects will be listed in the upper part of window. Mark the GPS and it will be listed in lower part of window. Click on it and start this “connection registry”.
After that you can use the navigations software. Go to “GPS status” and there you must put some check mark on some green quadrangle.
Sorry I can not explain you exactly what it was but I am sure that in User`s manuals of TomTom you can find a right explanation.
Toshiba e830...
Answered
on Sep 08, 2005
Windows Mobile 2003 SE Kernel ROM update error
I have already updated my e800 with Windows Mobile 2003 SE. I have had just a small communication problem between the notebook and PDA but there was no problem with update installation itself.
If no one can help you try to contact hotline or service partner in your country. I hope that they can give you a proper answer why this error occurs.
Toshiba e830...
Answered
on Sep 08, 2005
Rom Update
As far as I know there is a big difference between Japanese and European images and you can not compare them at all. If the Japanese image has a bug or if there is some problem that can be corrected with a new update that doesn’t mean that European units needs an update too.
Many of your questions are not completely understandable and I can just give you an advice to use a new BT driver (question 5). I have also 1 GB SD card and I use it with my e800 without any problems. At the beginning I thought that it will be read slowly but I am very satisfied with reading/writing speed.
Toshiba e830...
Answered
on Sep 08, 2005
