20 Most Recent Seagate GoFlex Slim 320 GB USB 30 Performance External STBE320100 Questions & Answers
After you plug in the external drive, go to windows explorer and and you can drag the files to where ever you want them. Create folders on the usb drive to keep order in the file tranfers.
Seagate GoFlex... | Answered on Apr 17, 2014
To help you out there I have found this easy setup guide for using an external hard drive on MXQ Pro 4K. This will help you for sure. Watch movie on MXQ with external hard drive. Hook Up External Storage to MXQ PRO 4K Android TV Box
Seagate... | Answered on Feb 21, 2020
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?
On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible.
Does the drive show up in the File Explorer / Finder of the machine?
after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
Seagate... | Answered on Oct 20, 2019
I need controller for (English please)
in a computer,. or DVR or what, where does this HDD go?
Medalist 4310 (ST34310A) built in 1999 (20 years old ) why use any drive this old.
why? it's useless.
my wild guess, is this
you have a PC and ustated PC has SATA only ports (modern)
and this old old HDD is PATA drive, with ribbon cable wide.
and you think it can run on modern PC.
well they do sell cards (PCI-e) that fit and work.
4.31GB is the size , holds about 1 top movie .
are you going to boot from this drive, if yes, very complex answer I will skip here. (ask maker of card , if it can)
newegg.com has them all, any thing you can dream of , is there.
if you look.
https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB8ZU9127&Description=pci-e%2c%20pata%20IDE%20card&cm_re=pci-e%2c_pata_IDE_card-_-17Z-0007-00AF2-_-Product
again, no PC stated, no OS stated.
nor of booting is needed to the PATA relic drive. from 1999.
Seagate... | Answered on Apr 08, 2019
unfortunately it appears that the internals are shot
if the funny noise is a clicking sound or squeal then the repair is a new hd unit as they are generally not repairable.
Seagate... | Answered on Mar 27, 2019
Tutorial to recover data from dead Seagate external hard drive
Step 1: Download & install iBoysoft Data Recovery on your computer.
Step 2: Connect the dead Seagate external hard drive to your computer.
Step 3: Launch iBoysoft Data Recovery and choose the dead Seagate external hard drive.
Step 4: Click "Next" to search for lost files on the dead Seagate external hard drive.
Step 5: Preview the searching results. After that, select the lost data and click the "Recover" button to get them back.
Step 6: Have a check to ensure all lost data have been recovered.
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive.
So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible.
Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer.
This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive.
The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more.
It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop.
Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
Seagate... | Answered on Mar 26, 2019
Format the drive in Windows and the MAC will read it fine ..
Seagate... | Answered on Feb 19, 2019
Try the following, change the usb port you are plugging it into.
Seagate... | Answered on Feb 07, 2019
whom i think youre seagate is on reading mode or not yet ready to use due to its still reading the data in the disk try the link below so you can follow there instructuions HDD External Hard Drive Corrupted and Unreadable Storage
Seagate... | Answered on Dec 29, 2018
you might have to go in and setup the drive. most new drives are not set up. you have to go in and setup the drive and format it for it to work
Seagate... | Answered on Dec 20, 2018
I usually figure 2 or 3 years for a hard drive life cycle. After that, I figure I'm on borrowed time. First try to check the disk for errors. Then try to delete the volume on the disc, then format - be sure to click "restore defaults".
Seagate... | Answered on Nov 15, 2018
Seagate GoFlex Slim 320 GB USB 30 Performance External STBE320100 Logo
1 questions posted
Top Seagate Computers & Internet Experts
Michael Thomas
Michael Thomas
ChinthakaJ
ChinthakaJ
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
move data from main hd seagate slim
  • Computers & Internet
